CJ10a big block Caddy 500 Rat Rod 😈
Yes..... For now. However, i did round up a divorced np203 just in case. 😉
Thats gonna make for a nice unique tow pig for sure. Should turn more heads than most things out there. I would drive that for sure.
Sent from my SM-J320P
Engine/trans installed...... didnt squat much.
Suggestions on how to lower the front end on a budget?
1/2 ton springs? Cut these springs?
Lift the rear to match? Is the front just higher than you want or is it a problem?
I would say lift the reat to mtach or are you wanting it low?
I've just caught up on Las Vegas RatRods. Bit of inspiration there to stick a hair dryer or two on top of your motor. They sure are crazy rigs. Not a fan of their "signature" billowing though.
Used stock motor mounts and fabbed up some brackets. Hope my amateur welding holds up. Vac booster had to go for clearance, but already had a couple of hydro-assists laying around. :thumbsup:
I've been wanting to follow this thread from the beginning. For some reason I can only access the first page. I can click on 1, 2, 3, or last but only page 1 comes up. Maybe by replying something will change and I will be able to see how this is turning out.
Happens to me as well, only goes to the first page each time it is accessed, even on the new posts link.
Also, the only post that shows it contains a "new post" after I was the only new post. (just adding this for possible troubleshooting)
LSUtiger, Love the build and will deal with the extra step.
Subscribed!:popcorn: :wave:
Working fine on my iPad.
