I like it very much, are you going to build the cage to the front too? I'm in the process of building my 6-point rool cage too. I'm going to get rid of the factory roll bar. Did you tie your cage to the frame or the floor board? I'm thinking of tying to the floor board with 1/4" plate on top and bottom to sandwich the floor board, what do you think? It seem like it would be a lot of work to tie to the frame.
Kristy,
M.O.R.E. offroad makes an out rigger kit that welds to the frame to tie in your rollcage,they look like the frame mounts but longer and beefier,and if you have a body lift you they will make you a kit with everything that you need to tie it into the frame,this set up is way stronger than mounting it to the floor which can shear in a hard rollover,If you call M.O.R.E. ask for Chris Overacker he's the owner and more than likely will answer the phone if he's there.-JC
I found the bumper in the For Sale forum over at Jeeps Unlimited for substantially less than the retail price and that's why I went with it. Plus, the thing is quite sturdy, rugged, and, dare I say, good looking.
When I saw "over the pass with 454" I was expecting some killer swap pics! I just got mine back on the road. My 2 weekend 350 swap ended up taking 3 months (yeah, I slacked off alot). But this thing is amazing with the V8! Now I'm wondering what I'll break next!
The work of a deranged madman/ex-welder. The factory front roll bar and tie-ins over the wheel wells are from the stock roll bar. The rest is 1 3/4 in NASCAR series cage tubing covered in 3in. roll cage foam. As you can see it's tied into the removable brackets on the back. MAYBE not good for 80mph roll over, but a regular roll over would be fine.
You can see the foam a little easier. I'm in the process of making the front part and the top cross members will be bolt in so I can still use the half hard top. I was thinking of making these for sale if anyone would want one. Either bolt-in or weld-in. Any Ideas.
I also will make these (simulated) Wrangler half doors out of 3/16-1/4 plate including the door handles. Hinges wouldn't be included, but the holes would be pre-drilled. Probably about $100-$110 pair and will need to be painted.
Scramblerace........Deranged madman is right. What is that Jeep going to end up weighing with all the pipe and welding rod figured in. Are you planning on beefing up the frame for these add-ons. If you drive to Oklahoma, I'll donate some widetrack axles for it (a little more weight). I'll also throw in a whole truck load of goodies..........maybe you can bolt them on somewhere !!
later,
PS. The big bucks are out sniffin the does !!!!! The PSE is still a virgin though !!!
