Curent pics, lets see em y'all!
cj8wheeler said:
Mark, looks good.... couple of questions.
Did you move your front shackle mounts forward?
How long are the front shackles?
are those std 5-leaf YJ springs in the front?
Thanks,
Todd
Shackle mounts moved forward. The mounts have two holes in them. I positioned the first hole (the one away from the eye of the mount) above the second hole on the frame of the Jeep (about 1-1.5") welded in place then kept installing.
Front shackle are hand made with bolt holes 4" center to center.
The front negative arched springs are the JC whitney heavy duty 5 leafs. I got them used (all spring sets) for $20, The rear is fine so I'm not going to complain.
I intend to get the Rubicon 1.5" YJ SOA 5 leaf spring packs for the front or possibly just the RE Add-a leafs.
I am also having strange breaking issues it's all covered here if you are interested
http://www.snort4x4.com/cgi-bin/Yab...ard=General_4x4;action=display;num=1044034752
and intend to fix it with $$. I am getting a bunch back from the Govt and am going to spend a large % of it on my CJ.
Mark
Chris House's Scrambler
Chris asked me to post some pics of his Scrambler so here is the first one-JC
Chris House
Here is his other pic of the black beauty-JC:D
Well my pics are on Yahoo and cannot be linked so here is the link to them at Yahoo
Scrambler Pics
These pics are not up to date anymore, I have since flattied the front fenders and put modified TJ flares on them.
I still need to cut the rear fenders for more tire clearance, I just have not had the nerve to do it yet, plus I haven't figured out exactly where to cut them to get the most out of the rear TJ flares.....I'll get my nerve up sooner or later...I'll post some newer pics when I remember to take the digital camera with me over to my friends house where the Jeep is.
kerryp
I might as well throw it up here too... in case you guys haven't seen it enough already :D
Cutting the rear flares is a tricky task.
SInce the inner wheel wells are attached to the body there isn't much to cut off. What I did to clear my 36" tires was to remove the flares, then I used a hack saw to cut a gap every 12" or so from the tire side of the fender up just to where the Body meets the inner wheel wells. Next I took my BFH (Big F***ing Hammer) and beat the lip up into the wheel well. I got about 1" of clearance as well as kept the integrity of the body.
attachment.php
FIRST OFF-ROAD TRIP
This was my first off-road trip and the folks at Long Island Off-Road (LIOR) took me to Paragon park, PA. My "8" went through a ground up restoration in 2001 which took almost a year. The first 10 months of 2002 was working out the kinks. The stock 258, T-176, D300 were all retained. The upgrades were: HEI distributor, Weber carb, Warn XD9000i winch, Warn front bumber, 4 inch trail master suspension lift with SSV shocks, 15x10s with 33" Pro-Comp Mud-terrains, Sun Performance rocker guards under the doors which actually fit "8s," diamond plate rear quarter panels, one piece rear axles, 4:10s with ARB lockers front and rear, Bullet Proof rear bumper with rear swing away tire and duel jerry can w/ high lift jack mounts, New seats with tuffy console w/ stereo inside, fold and tumble rear seat, no interior wall, full Specialty soft top, Stainless dash w/ new gauges, Cyntech harness, 20 gallon tank with skid plate, new front axle shafts w/new tie rods, and rolled in linning inside and underneath.
I took the moderate trails and in half a day I blew one front axle U-joint (kept ARB locked in a turn) and kept the gas in it and torched the lobes of the axle shafts, pushed the gas tank and skid plate about 2" higher in-between the frame cross rails. It still was a good trip and I probably need to go to off-road driving school.
If anyone wants to see some pics of the buildup or the finished off interior let me know and I will post.
Karl
Karl's Trail Ride
Karl as my buddy Rick would say "you had a good day";) -JC:D
:D :D
Ha Ha, that's funny, considering you bobbed your 8!
:p
(No offense! IMHO, it's YOUR Scrambler, do what YOU want to it!!!!)
Postal from AK to AZ
Brought this one down from Alaska to Arizona. New/used Kayline top!
Sell'n the old AMC Postal top...
Finally got around to taking a couple pics. They didn't come out so well though.
recent pic
this is one of my latest photos of my project.i have not posted in a while.84 cj-8 bobbed,4.0,9" front and rear
Hey Fisherman, where's Brunswick? I'm from WV and that town sounds really familiar. Is that near Deep Creek Lake? Have an uncle in Mt. Airy too, so have spent some time in that area of the state.
