Got it ready to work on the heat and other things in the garage late yesterday so off came the plow:
Today was cleaning out 39 or so years of crap in the heater box, the blend door was stuck in place and heater core only half exposed. Mostly leaves and twigs.
While my scrambler sits in the garage this Winter patiently awaiting my attention for a couple of projects, I was asked by Jims Chop Shop to post some current pics.
The 8 went through a couple of minor changes this year, most notably the front fenders. Started out with YJ fenders running TJ flares, then went to fiberglass CJ fenders that were slightly modified, and ended up with a set of tube fenders running a 6" flare.
Took this pic on the way in my driveway today, not one i drive in every day. With tracks made on Saturday only in 8" or so of snow, then a melt and heavy freeze, arriving 4 days later this was created:
Factory limited slip rear differential, which jeep called "trac-lok". If optioned that way, they put that sticker on there and the ratio code on the dif was 2 letters instead of 1.
Yesterday was a good rainy day to scrape and paint more rust on the plow truck.
And added this to see if it takes care of my carb problem before rebuilding the other one. Last storm it was still acting up. This carb is really for an 80-87 ordered for my '84 but it should do for now. The ugly green air cleaner was in the parts pile, cause the stock cleaner wouldn't clear this carb with the bowl vent that sticks up.
7HP confirmed !! Runs out good now carb fixed the problem but ive got a rust hole in my oil pan but so back inside it went but it was a nice day yesterday to do some tuning outside. Moved blue renegade over to the other side of garage so gave that a run too.
