Custom CJ Dash
05unlimited
Lancaster
CA
How is this for a custom look for a CJ? Similar gauge arrangement as a YJ i.e. Tach on left of column, smaller spedo on the right, folowed by Fuel, Temp, Clock, Oil, and then volt.
The colored pod above the steering column contains the L/R Blinkers, 4wheel Drive, E Brake, and High Beam indicators. A custom machined polished aluminum backing plate behind the gauges lends a retro custom look to the dash.
You moved the passenger speaker, you might want to check that you will have adequate glove box space left (unless you pull all the associated heater ducting). I wanted to do the same thing with mine when I had it customized... Also need to think about pax grab bar and how it will look off-center with glove box moved.
If you were planning on a roll cage, then moving the glove box keeps it axcessable. I have a couple glove box doors that have had the right side cut off to clear a roll cage. Nice looking design.
Yeah, I know about the hardware behind the dash. The glove box is off to the right of center for the grab bar, so I just swapped their locations. Now the box is off center to the left. Since I have a cage installed and the right side of the box rubs against the cage, I could move the speaker and box over to the left 1/4" and still look stock. The OE speaker looks kind of goofy placed where it is in relation to the other speaker.
I always thought the OE locations of the speaker, glove box were stupid - make the music out of balance, and make it a further reach to the glove box... brilliant. Just poor planning. They knew they'd have HVAC. They knew they'd have a stereo. They knew they'd have a glove box. Figure it out.
And while we're at it, what's with the OE square speaker grilles? What's square on a CJ?
So, I rearranged it all too.
So now, the speaker - instead of the glove box - is "blocked" by the roll cage, and the glove box is reachable from the driver's seat
How about the HVAC stuff? do you have a heater setup in there?
Moving the glove box over a bit I wondered about if you would hit the computer (if you run it) or the controls for the upper heater box parts.
OT, but you can modify the hinges to slide to the side and then open. I have a cage in mine with the stock uncut door by doing so. I made a thread on here when I did it. Not difficult and has worked great all these years.
Interesting dash, looking forward to seeing it come together.
