On my current build I also used the 8” A-Team booster, master and bracket. I was a bit less than satisfied with how sloppy the tolerances were on the linkage, and ended up spending a couple of hours getting everything up to my standards. There’s a couple pics in my build thread. I can’t give any real operational feedback as it isn’t on the road yet.
On Copper I started out with the Pirate Jack 7” booster/bracket combo. I seem to remember the Pirate Jack bracket and linkage being better quality. But the 7” booster wasn’t quite adequate, so I upgraded to a Tuff Stuff Performance 8” booster and new master. I was satisfied with that.
It seems that getting a good proportioning valve is a problem- I went through a few before I got a good one that didn’t seep fluid. So- if you are still running disc/drum brakes I would recommend keeping the stock valve if it’s serviceable. On my new setup, I think I’m going to try the Wilwood adjustable valve. I’ve read a few complaints that it’s hard to get the lines to seal to the aluminum body. We shall see.
