Electrical question
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
I wasn;t sure where to post this so I thought I would just put it here. I got the 8 to crank over after doing the SBC swap. Thats good, light come on, wipers and washer works, Horn works, everything seems to work except the parking/flashers.
The parking lights stay on all the time, blinkers will not work, hazards won't work, the blinker indicator on the dash is on but only on the right.
Any Ideas?
I'm going to try the simple answer first....bad bulb(s). What you're describing is what happens when a bulb burns out. Did you try new ones?
Next, I'd go for bad grounds.................
Nope that's not it. All new bulds and all have been checked. But when a bulb goes out the parking lights don't just stay on all the time do they? As soon as I hook up the battery they come on.
forum
Just had to vent. Okay, i have the light all working but the right side is considerably dimmer that the others and when I hit the brake the lights on the right side get screwed up. The reverse light goes bright and the brake goes dim.
OK...I've been wrong before; just ask my wife and sons. :o
types of bulbs
check the bulb types to make sure they are the correct type. I beat my head against the wall for about 2 weeks with this one when I rewired that YJ front clip with the other headlights. I had the wrong type of bulbs in the turn signals and was throwing off the blinkers and signals. They were all good bulbs, I just had the wrong type in there.
It was really the CJ gods that got you for blaspheming that '8 :D
Good One :D
Okay now everything works and works right execpt the right side will not blink and the indicator stays on and the front right turn marker on the grill is brighter than the other. All have the right bulbs.
weird things can happen with d.c. systems...a short to ground can cause some wierd "back" circuits...i once had an autoreverse tape deck in my cj5...and...when i hit the blinker it would change sides of the tape..never did figure it out...
one thing u might try..with everything off..take an amprobe and see if any of ur wires r showing any current flow...if they r, u have short ......also check to make sure every fixture is properly grounded...on a jeep electrical problems can almost always be traced to a bad ground somewhere
Thats funny, Just like a when i first hooked mine up and hit the horn. heard something, wasn;t sure what t was. it turned out to be the new washer pump :D
OMG I can't believe this. i went out and decide to check the flasher again. Pulled one flasher unit and it was fine. Put it back in, pulled the other and it was fine, put it back in. same problem as before. I sat back and thought for a minute. it's a Jeep right. I pulled both and swapped them. I put on in the others spot and I'll be darn it worked. Flashers now work :D
I spoke too soon :mad:
Okay, the flasher works when it is not screwed into the grill, When I screw it into the grill and it get's good ground it works fine until I turn the light on. When I turn the lights on it just Stays on and stays on very bright. Any ideas? The back one and the side work fine.
Very nice almost finished CJ8 project for sale. new paint, chevy 350 engine, it does have a few electrical issues but nothing major :D
I have just about had it :D
Oh alright since you insist and I want to help a brother out...I'll give you $20 for the whole thing...I know that seems generous but I know you have put a lot of work into it with no payback so I want you to feel good as you see her go... :eek: :D ;)
Truck
Gee Truck, you a good man. Only problem is, it now has no electrical problems so I would have to take quite a bit more :p . i got it all. It seems that a 5 yr old in China swapped some wires on one of flashers mounted in the grill.
EVERYTHING WORKS!!!!!! :D Wel almost.
Sounds great, I can't wait (can't believe I said that) to be dealing with the 'final' gremlins..
So I'm guessing $50 wouldn't even pry her away from you now.. :rolleyes:
Truck
