Finally some progress on my 8
WOW!! That's really a great looking rig you've built. I was wondering what brand of headers you're using, they look custom made?
Seejayate
The first set of headers I bought were Sanderson.......they were alrightbut didn't quite fit with my motor mount scheme, learned a lesson-ALWAYS have your headers on before you design your mounts. The bling stainless set of headers is from OBX and they are 100 times nicer than the sanderson headers and they were cheaper if you can believe it!!:thumbsup:
Thanks Doug, I like everything I've done thus far except for the floor but I had to keep the floor low and I learned I am no sheet metal guy.....how is your scrambler coming along?
Thanks Cape8. It has been alot of work but I know it will be worth it when it is "done".
The front part of the cage is all tacked in and drivers seat is mounted. Decided to do a traction bar so I can get it done soon to wheel so I can work out any bugs, I'll prolly link it over the winter. Pics to come soon.
:rolleyes:Got most of my traction bar finished today....awaiting some bushings to do the shackle end. Got some bilstein 5150 shocks for the front and got those mounted up. Should get more of the cage done this weekend....pics to come if I remember the camera:rolleyes:
List to do:
Driveshafts & axle yokes
e-brake...bleed brakes--run vacuum line for booster & trans.
Rear shocks
Rear lights
Rear bumper
Mount the trans shifter
Finish cage and mount the tachometer
Sliders
Exhaust
Skidplate
Last inspection of all fasteners.
Drink a few beers............:cheers:
Smoke some tires and break something!
With alot of help from my mexican Jim we got the basic cage layout done and got the seats all mounted up so the whole floor section could be removed.Also finished most of the traction bar(still awaiting bushings for the shackle side). Also with some advice I figured out how to mount my shifter and have some dry storage in the process via a .50cal container. Next we'll do some finish work on the cage.
Added some more tubes.Still have a variation of an x behind the seats and some more short tubes, door bars and a bar up front. Then some finish welding,re-install and make some tabs for the aluminum roof......man I'm tired just thinking about what is left!
Plugging away at the cage
Got some more done on the cage today......the top design is almost done. Still alot to do.
I got the traction bar all tacked in tonight. Progress will be slow for awhile as striper and tuna fishing is looking like it might be getting good really soon.;)
WOW! Having worked on quite a few similar projects, I can appreciate the approx 1 Million man hours you have put into that cage . . . . unless you are like Costanza (Seinfeld) after commenting on the Gugenheim . . . "Really didn't take that long", lol.
HOLY MOTHER OF ALL CAGES!!!! WOW!!! :bow: :bow: :bow:
Screw a rollover, that thing will be able to survive armageddon!!!
Thanks guys...this project has taught me alot....I have a new respect for people that fabricate. Certainly a labor of love.:crazy:
Great looking cage.
Pirate folks would probably balk at it and say you need more triangulation or something.
I think it looks like a good, strong design. Well done!
Great looking cage.
Thanks, my friend Jim designed the cage with some of my input, the guy is pretty talented.
Got the cage top design finished and about 80% welded....now I need to tie it to the frame and rip it all apart and finish weld it and get the tabs mounted for my aluminum roof.
Got the front shock tabs welded in, Plan on doing alot of finish work this weekend. Got the yokes for my 60's and having a local guy stop by to take some measurements for my driveshafts sometime in the next couple of weeks. Plan on building a skid plate this week. Should be moveable soon......:eek: I'll post some pics if I remember to take some.
Been slacking really bad lately, got a little bit done. Replumbed the fuel system and took the filter out before the fuel pump as the pump sounded a bit loud like it was fighting the filter, It is now much quieter. Bled the brakes and master cylinder... a ton of air in the system as the entire system is new. Ran the vacuum line for the transmission and the vacuum assisted brakes. Wired up the rear lights.
Awaiting the driveshafts and then it is on to the skid plate. Still alot to do. I'll get some pics when there is something worth taking a picture of.:rolleyes:
Lookin good Wil, keep the updates coming.
Can't wait to see the finished product in person
Thanks Lee, I'll be a happy man when it is driving under its own power again!!!
Plugging away....Got the door bars done and finished welding the cage. Seats and harnesses all mounted. Finished the rear of my aluminum roof tonight, having a friend bend up the front piece of the aluminum roof in his huge roller bender. Driveshaft parts are all ordered and on their way. Broke my digital camera taking pictures of my friend Jim's buggy vortec swap and revamp.....I'll take some pics when I get a new camera.:rolleyes:
Couple of pics of the seats mounted I was able to salvage from my camera after it jumped from the tire to its death.Got a new one tonight!:thumbsup:
