Finally some progress on my 8
A couple of pics of the cage and the rear aluminum roof. Awaiting the front roof to get bent up by a friend. Then its on to mount a couple of tabs, get to painting and then throw it all back together and finish the frame tie ins and presto, cage is done!!! WHEW THAT WAS ALOT OF WORK!
:cheers::cheers::cheers:
amazing cage work, after failing miserabley this summer on a much simpler one I am in awe.... I would lik to see how your shifter/ammo box mounts and works, i have an Art Carr in mine which cost me the console so that looks like an interesting solution that might work for me too!
Thanks Trust, I can't take credit for the cage design.......I just bent & cut the tube.I'll post pics of the shifter when I decide how exactly I want to mount it, can't take credit for that idea either, Jim also came up with that.
Big thanks to to the guy who bent up my roof, he did a great job. Finished the front roof and painted the cage. Ordered my driveshaft parts from driveshaftsuperstore.com and they sent the order to the wrong address two weeks after I placed the order and there are parts missing, there is no invoice...no explanation and they have yet to respond to 3 voicemails and an e-mail (I just saw they are only the bad sellers on NEOW, oh well, lesson learned). Thanks DriveshaftSuperstore for your customer service, I don't know how places like this stay in business when good places continue to go under???? Anyways, here are a few pics....Let me know what you guys think:thumbsup:
Got the cage back in the jeep and will work on the frame tie ins this week and get the seats in there.....then on to mounting the shifter. Then driveshafts and it will be moveable!!!!!
List of things to do:
frame tie ins,mount the sliders
e-brake
wire up the tach
wire up reverse lights
driveshafts
skidplate
rear shock hoops-order up shocks
front end alignment..weld on the inner c
exhaust
Rear bumper/tire carrier
check all fasteners and all fluids and take it for a drive!:eek:
Snapped a couple of pics of the roll cage mounted up....still have to do the tie-ins, I'm slacking this week. Maybe I'll go down later today?
Frame tie ins are done and mounted up. Finished mounting the the poison spyder rockers..... Now just have to take it all apart and paint it. Hopefully will get the driveshafts this week.Pics to come next time I'm down the shop.
awesome cage, but I am curious about the diffs what is the wms on these? did you cut them down yourself? if so did you take off one side or both? love the width on your 8
Thanks...The width should make it very stable, I just need to lower it....I'll do that when I link it.The rear axle is aTJ width solid 60 and I cut down the long side on the front- I think it was something like 4 inches off the long side.
Picked up the driveshafts yesterday. Should be able to get it moveable this weekend:eek:
Got the rear driveshaft in and built a mount for the shifter. I Started it up tonight and drove it back and forth in the shop...Need to get it on on alignment machine and finish welding the inner c,fabricate a mount for the front 2 piece shaft, fabricate rear shock mounts, build an exhaust and fabricate some skidplates before I take it out for a shakedown run. Still alot to do:crazy:
A little video of the jeep moving under it's own power!
http://www.youtube.com/watch?v=yKGO133wWjw
Nice Will, like the title says, "finally some progress" but the mods have been impressive.
Good job
Got the front two piece driveshaft mount welded in tonight. Now need to get the front shaft built up..........will hopefully throw the jeep on the trailer on Friday night and get it on an alignment machine to burn in the inner c !!!!:evil:
I couldn't believe it, with just eyeballing and a digital angle finder, the caster was dead on to factory spec and the camber was off by .2 degrees and still within spec. Burned in the knuckle on Saturday night and bolted in the front driveshaft.
Took it for it's first rip run down the street with open headers...........WOW was it fast :D and I got some interesting looks from the neighbors with open headers:angry:.
Ordered a Kevko racing pan with the fancy trap doors in the bottom of the sump to help with the common oiling issue with these motors when you run them uphill/downhill or sidehilling for too long.This pan will not look as attractive to the rocks as it will be much higher than the factory pan. I'm going to need run a remote oil filter as the Kevko pan doesn't have a provision for the oil filter. Decided to not run an accusump or oil cooler as it really isn't needed for my application. My shop partner also finished his 6.0 swap in his buggy and I got to drive that on Saturday.......I think I need a buggy:shrug: Still alot to do until it's temporarily done!:smokin:
I'll post some pics if I remember to take the camera down the shop next time I go down.
A few pictures of what I've been up to lately and how it sits as of tonight. Still have to do exhaust,skidplate, ebrake,paint(thinking victory red or big bad green) and a few other odds and ends.
I love having a high pinion in the rear...shoudn't ever hit the driveshaft:shrug:
Murphy's Law Motorsports Driveshafts- These are super nice!:smokin:
A few more pics
Crazy loud horn, it made me jump 2 feet in the air the first time I heard it.
Thanks Eric...It's amazing how quickly all the space I had in the engine bay has filled up. I still need to do some cleaning and finishing touches so it looks a little better.......I think my next project will be a 55 chevy pickup with a modern drivetrain and some modern amenities, I saw one at the barret jackson auction with a mercedes dash and drivetrain that looked super clean. I fell in love with that truck instantly. Now I just need to find one with a decent body & frame:evil:
Ok, we'll let you build a non-Jeep, so long as you do a build thread on here for us to watch :evil:
Sounds awesome.
Chipping away slowly this week. Did some of the small stuff that eats up time. Got the rear shock mounts done and ordered up some bilstein shocks for the rear. Finished ordering the last parts for my exhaust. Once the exhaust is done it's time for a skidplate and then off for a shakedown run. I can smell the finish line.:D
