frame?
madjp62
albany
or
what would be a good price for a scrambler frame? doing some home work before i buy. thx guys
New - Roughly $1900 + $600 shipping ($2500 total) through AFW.
I bought my '82 frame as a rolling chassis for $1200. Price would have been $1400, but the seller found a crack in the frame about an hour before I was supposed to get it...he then knocked the price down. It was essentially rust-free, but had a couple flaws. It included wide-track axles (4.10), wheels/tires, PS box, and 20-gallon poly tank/skid plate. I traveled ~13 hrs. one-way to pick it up, though.
Craig
frame prices
I recently sold a frame with wide track axles attached for $900 i believe. It was in very good shape, straight, but needed a new rear crossmember.
that was with the axles too.
new ones as noted, are going to be around $2000 + 400-500 for freight.
Matt
thx i may look up AFW and see where they are located. i drive simi and
i kind of have free shipping. frame would be easyer then when i put the scrambler halftop inside the cab.(i team with my wife,she was a good egg
about it).it was like having a reloving door between front+back of the cab.
frame could go in trailer or under it. i'll do a google sherch for AFW now
ok,next ? what is the diffrence between cj8 standard and the bobbed?
About 12".
The wheelbase is the same. Bobbing usually involves takeing about 12" of sheet metal between the rear tires and the Aft body seam. Mostly done for serious 4x4 use as it will eliminate the tail dragging part of a scrambler. Basically looks like a CJ-7 from the rear axel back.
Carl
ah i under stand,not want that. i'ld had goten a cj7 if that was the case.
hey thx for your help.
