front spool installed
scott anderson
Old age Mutant Ninjaneer
Paragould
ar
well got the spool in my dana 60...so to all that said i could not steer..u are mostly wrong....i dont have the twin stick installled yet ...but i went out with my daughter.and i was able to steer with throttle....bottom line ..i love it...amazing what true 4 wheel drive will do..it just seemed to crave off camber ...thank u scott mine for the enlightenment..
Welcome
Scott ... When you get the twin stick in you will notice that you can turn sharper than without the twin stick. I love mine and would not change it. :cool: :D
Did i read that right u spooled the front.............I put mine in the back and for the most part i love it except on muddy off camber stuff then it wants to walk down hill and your constanly fighting it.
scott anderson said:
yes...spooled the front
Be interesting how that works after some time......i have an ARB in the front of mine,but i dont have lockouts I've got drive flanges and it's a PIA to steer when it's locked in.............but we have lots of off camber muddy hills here.
the way scott explains it..u steer with the rear disengaged...i can see where slick off camber would be a ***** if either end is locked..my limited experience so far is on the off camber ..when u hit the throttle the rear slides down and the front steers up the hill...
yep thats pretty much it.......rear wants to walk down.......front wants to pull.................still playing with mine and what works the best so time will tell
I noticed the serious increase in difficulty steering when I went to the Detroit up front. I have the twin stick setup in the garage, just never got it installed, so I'm looking forward to trying to steer with the front as you mention.
You can steer with both ends engaged, you just get a really big turn radius. Steering with the throttle gets old. After 6 years of welded front diffs I bought a detroit, haven't got around to installing it yet. Main reason in switching though is that I don't want to run lockouts anymore, and I still think jeeps are fun to drive on the highway.
Steering
Yeah i do have a HUGE turn radius, but that is why i have the twin sticks. That helps out alot. I just did not have the money for the others at the time and now that i have learned to use it i do not have a problem anymore. I know people that have installed an ARB and and they are great but i have had NO LUCK with stuff like that. I like to practice the K.I.S.S (Keep It Simple Stupid) program as much as i can. So that someone like me can actually work on my Junk cause if you have wheeled with me then you will know why. :D :cheers:
i did not have money for an arb either..and i have heard all the maintenance issues ...i guess the jury is still out but i think i am gonna like it....
one more caveat...my rear is not yet locked...saving my pennies for the detroit...so thay may have helped hold me on the side hills...
I have never found any drawbacks to the welded rear diff.
As for that KISS principle, I chose a detroit instead of lockout hubs. To engage 4wd, shift 1 lever. No getting out to lock hubs.
