Front wheel burnin fun
Houston
So there I was, showing off my twinsticking on the street and.......
attachment.php
Lesson learned: Don't weld in your ujoints with a mig. :D
Got the inner, outer, joint, and I think the balljoints.
And here I thought you maturing nicely.....
Where you been Ryan? Showin' off for some chicks I'll bet.... ;)
I guess, maybe, I should hold off on trying this.......... :rolleyes:
There's a time and place for everything Bill, and that's college.
Try it out John, here's your chance to proove your jeep is stronger than mine. :D
Today I get to replace all that stuff, and do a little modifying. This time I think I'm just gonna replace the needles in the caps with bushings and weld em in. The spares I just bought off ebay are gonna get something extra special.
Ryan i don't see a picture??????????????? :(
Long time no hear from...
Thats what happens when ya get it to hot.. :eek:
Ouch... it's only money and time. Are you going to upgrade?
z
Was'nt that the name of one of the extreme trails out in Hot Springs? The one that had broken d44/d60 axils, ring, pinion, knuckles and a multiple of other parts hanging from the trees? :eek: Brings back such fond memories. :p
z :D
I've been trying to upgrade for a while, those bigger axles just don't come free. Usually its only time. That's the first time the shaft has let go, usually its just the joint, specifically the bearings in the joint.
No more bearings.
Ryan, the bushing idea is a great one, just make sure you use a greasable u-joint.
Also if you plan on welding the caps in try grinding down the "monkey ears" about 1/16". grind the surface where you previously welded so the cap sticks out 1/16" from the ears Then you build up the ears with welds.
One more tip if you try welding in ujoints with needle bearings, try submerging the axle in cold water up to the surface being welded. it helps cool thing off.
Thats how I did my welded in caps , seemed to work.
I still broke chit though.... :D
They're non-greasable. Why do you reccomend greasable? Did you try both? What type of bushing material did you use? I used sintered bronze.
I ground a bevel into the yoke holes for more penetration.
If you can't grease them they tend to squeal after a while.
I didn't go so far as to use them (went to the 60 before dumping any more ca$h on my turd of a 44) but did have friends that used them and a friend that was making the joints, ,He didn't use bronze he used some high carbon steel.
Hope this helps!
Ryan,
I was literally in your neighborhood earlier this evening. I went up to pick up some stuff I traded for with Island Doc, and while talking to him and his wife, she said she's seen another Scrambler in their nieghborhood while she was out jogging....She said it was red and sort of abused looking.... :rolleyes: It had to be yours....He's got a pretty clean specimen with a SB 350 in it.
A trail named Carnage
Was'nt that the name of one of the extreme trails out in Hot Springs? The one that had broken d44/d60 axils, ring, pinion, knuckles and a multiple of other parts hanging from the trees? Brings back such fond memories.
z
Hey Jeff, I thought that was "Chigger" Trail where all the Carnage was????
Ryan, Are you sure it was worth the cost to try to impress the Sweet Young Things in College Station?
Later
She must be spacial....
It's been my personal experience that you can thoroughly impress them for a lot less money than that....That sort of money should only be laid out for special times like proposals and such......"Honey...i love you so much I would gladly grenade my axles just to be with you..." That sort of thing.... :) An example of a more casual impression would be rubbing the painted part against a tree/rock while they were off roading with you.....
so what's the date Ryan? :eek:
