Griff04
- Albany
- Ga
Well I jumped off into my fuel and temp gauge no working. I'm replacing the windshield, already off, so I just unbolted the dash which gave me some room to work. Boy was I surprised, what a mess, the PO had installed a aftermarket radio which doesn't work, made a mess out of the wiring, found some type of small amp, just a dang mess. Along with all that I found the duct missing for the defrost so I know it's not working. So be it, just suck it up and move forward.
Anyway, been reading up on the gauge issues, there's enough info out here on grounding it makes my head hurt. With the dash pulled out I noticed some rust along with a couple grounds just hanging loose. Gonna try and trace all this stuff out and see where it goes. I'm hoping this won't be too painful but it ain't looking good.
Anyone got any advice before I dive into it??
Also I notice a fuse mounted in the dash located just left of the steering wheel, it's one of the bulb style, it's not hooked up, does anyone knows what it is suppose to go to?
Thanks,
Griff04
Thanks,
Griff04
Maybe sand the inside of the 12 volt plug, maybe compress it a bit more so that is has a good contact
