- Cave Creek
- AZ
Seems relevant to this thread:
I have that transfer pump. It is frustrating because you have to hold the hose on the pump, BUT if you can get those 3rd and 4th arms in play to hold the hose, hold the pump, manipulate the pump handle, and hold the other end of the hose into the whatever you're filling, it works great!
Just bought the HF #60827 Ball Joint Service kit. Will be using to replace joints in my Dana 50 IIF front end. Hopefully this weekend.
Will let you know how it works.
Used it tonight. Removed and installed 4 ball joints. Clamped it upright in a vice. Then went to work. PB Blaster pre soak. Only drawback was one of the joints was too long for the adapter. Just happened to have a piece of pipe with the correct id. Cut a piece just the length needed. Worked great.
