That's correct. Currently it'll be running a dual-sync distributor to run sequential fueling but in the future it'll have individual coils mounted on some sheetmetal aluminum valve covers. The XIM has been mounted and wired so it should be a seamless transition when the time comes. Right now it's getting put together for the purists I guess. It'll also end up getting a 4L80E later too. That way the WOT shifts can be programmed so it'll be a hands-free car down the track.
The engine builder should be back at work today so the rest of the motor will get assembled. That means it'll then get put on the run-in stand and fired up either tomorrow or Wednesday. It's getting closer-
It's time for another update. The motor is now completely assembled and put on the run-in stand for start-up. We ended up having to rebuild the fuel rails from scratch because the heli-arc put too much heat into the cromo and it developed cracks which leaked the fuel. They are now braized and all is good..... With the motor on the stand and a torque converter cut apart to use only the ring gear off of it, it time to get this thing ready to run. With a little programming, it fired right up and revs up like a sprint car motor. So far so good. Now it's time to put it in the car. The last one is a video-
This morning we had to modify the air valve linkage to make it progressive. We found out pretty quickly that it takes very little throttle movement to RPM the motor with eight butterflies opening at the same time. Here's another video we just took getting another heat cycle into the motor-
