Here's my new ride Finally found
neilconnolly79
Mankato
MN
me a Scrambler!!!!
It's an 81 needs some TLC and a lot wrenchin, it's my newest addition to the Fleet
http://www.flickr.com/photos/srbeaver/5462804193/in/set-72157626098434354/
Sweet! What are your plans?
I've got a 7 right now that I'll pull the T18a, twin stick 300 locked 30 and 9" and 2.5 springs out of and put in, and possibly the 258(pending how the one in tit runs) then do the body work as money permits
Looks like the frame is in good shape. Good deal! Keep us posted on the progress.
I'd do the body work first, at least treat the rust on the frame and tub before it gets any worse. Right now it does not look too bad. You'll save money in the long run. You could start with elbow grease and a can of spray paint. :twocents:
I'm guessing the two dented fenders were the motivation for the world's largest cowcatcher bumper?
like Randy said.. frame looks good, everything else from there is (relatively) easy.. you can turn that thing around with a pressure washer and some spray paint.. good luck with the build!!
Yeah from the looks of it the Cow Killer was definitely an after thought, oh well not that big of a deal I'm thinking some PSC flatties are in order.
And while I have it on the lift with the drivetrain pulled I'll probably hit the frame with a grinder and a rattle can.
wire wheel on a drill or a flexible rubber pad with stick on sandpaper out to do it.. grinder would be a bit aggressive..
see your sig line and GA plates.. where are you stationed?
Yeah a grinder may be a bit overkill
I'm at Stewart for the time being, may be moving on to AZ in the next couple months pending a seat in school.
Thats a great place to start, Nice rig :thumbsup:
I agree with working on the frame first, it will be time/money well spent.
I'd wire wheel the frame, but use a grinder motor and a wire wheel 'cup'. it will work way better.
So if you pull the driveline out of the CJ-7, what will you replace that with?
So, no top for it? :confused:
Yeah, I've decided that I am going to just pull the body of and do the JKS 1.25 body lift while I it off and it will be easier to pull the motor trans tcase that way too. So I'll hit the frame with a wheel and some paint while I'm at it. As for the 7 it's gonna go down the road to a new home shortly after the swap is complete I'm gonna set the 8's drive train into the 7 a let it go:( don't really want to but I have to damn many projects anyway. And unfortunately no top but I have soft doors from the 7 and a new bikini that's gonna go on itfor the time being till I can find a soft half top.
Congrats! I went the "bodywork first" route twice now....In the below pictures, the first couple are what I brought home to a horrified wife and neighborhood. The second couple are (more or less) what it was after a trip to a dumpster and the bodyshop. This opened up a HUGE door to more mods when my wife didn't hate it anymore....just a thought. I think it''s cool that it is an 81....I wonder if it is an EARLY 81....one of the very first.
Looks like a great start. Stay motivated and post any questions you might have. Most of these guys have been there done that.
Wrench On.
Well, I got it in the shop today, and over all a succes in my opinion. Found a few things I didn't like but Sh!t happens on a 30 yr old Jeep. After about 2hrs of scraping crap off the frame and underside of the tub I found 2 bad cracks in the frame on on each side both had been attemted to be fixed but weren't done very well. I will be removing the PO's attemt at welding and plate around the frame completely in those areas. Would have had pics but my buddy dropped my camera into the oil bucket. But on the up side after not being turned over for 10+ yrs a little Marvel Mystery Oil in the plug holes and a fresh can of fuel it popped right off and ran on it's own for a good 10 minutes. Will need a carb rebuild, as that is leaking due to the float being most likely stuck, lots of vacuum leaks to deal with, but had 50psi oil pressure right of the bat and sounded very smooth, with exception of the exhaust leak where the pipe rusted out at hte manifold.
NICE! :woot:
I fixed the photo in your first post to be a little bigger ;)
