How Is The Ride Quality In A Scrambler?
Sounds like a cake and eat it too scenario. You want comfortable 100+ mile seating for 5 in a less than full-size vehicle, you want low noise & heat in a vehicle with no insulation and removable everything that leaks air & water, and you want creature comforts in pre-90's 'SUVs' that were designed to be utilitarian. Get yourself an early to mid 90's 2-door full-size Blazer or Jimmy...reasonable room for 5, plenty of insulation & seals, and plenty of creature comforts.
If you are going to go that far why not just get a Grand Waggy...Although I still would rather have my Scrambler any day.
Truck
There ARE drawbacks to procreation. Allowances ultimately will have to be made. How about a Pinzgauer with troop seating?:D :D
Paul
Truck
Good call! I have one of those that I have used for moderate trail riding/daily driving and my tow rig. Find one w/the towing package. It'll have the better gears (3.31 vs 2.73) and a tranny cooler (assuming late model mid 80's - 91). If the AC doesn't work or you don't require it.......it's super easy to convert the York compressor to OBA!
I am pretty impressed how nimble they are on the trail for a full-size rig. Good turning radius and more narrow than your normal full-size rig. Mine has SOA lift in the front and 33x10.50 BFG's. Throw a couple of lockers or LSD's at it and 33's or 35's and you would have a very capable trail vehicle for less than extreme wheeling.
bigwalton said:
I did miss that, an LJ will certainly not seat 5 in any form. Even an XJ would be tight for any long rides.
Realistically, if you want to seat 5 and carry all your gear from CA to Moab, you're looking at a trailer, towing, taking two vehicles or something... A Scrambler set up to seat 5 won't do because you'll have no cargo room.
The long distance wheeling trips I want to make won't be with the whole family. So cargo is not a problem.
Andrew
Don't get so irritated. I am just looking for information.
Andrew
Had a feeling this thread would regress. Lighten up, guys
Anyhow, How about a Scout II or Traveler. They're like small Waggy's and are definitely TRUCKS. Real good stock on the trail and drive like a Caddy on the highway. Just TRY to find one rust free.
I still would get a Pinzi:rolleyes: :rolleyes:
Paul
Andrew
And I was giving you information...I was not/am not irritated in the slightest. I made some points based on the info you gave and gave a recommendation based on that. These vehicles (Broncos, Jeeps, Land Cruisers, Scouts, etc) are relatively spartan and utilitarian. They leak water and air at some of the seals where body parts fold or are removable, are noisy and can get hot/cold due to lack of insulation. Thems the facts. If that stuff doesn't suit you anymore, then you have to move into a 'luxury' SUV, or find ways to make compromises in the utilitarian nature of your chosen old-school beast. Seal everything up and don't fold down/remove body parts anymore, sound deaden & insulate and forget about hosing out the interior. You get the idea. The ride quality is in what you do with suspension & tires as everyone has already stated.
No problems.
This discussion is just like shooting the BS in someone's garage.
Anyhow, there was lots of good information. Helpful, even if it is not exactly what I wanted to hear.
Andrew
so, how DO you make a good riding CJ8? seriously ;)
Mine is going into the shop & a new 4 - 4.5" lift is on the menu..
RE? OME? Wrangler leafs?
I love my RE 4.5 kit.
I'd really like to add some adjustable shocks to the setup, but I'm waiting until I get the Ford front shock towers.
they are on my list, as I do have the ford shock towers :D
It's going in pretty soon.
Don't know about the timing for the December trip, it'll be close but "it" will be a much better all around Jeep :) :) :) :) :)
