Hydrogen Fuel Cell going into my old 81 CJ-8 as a test run.
Didn't the guy that posted this up say he was getting 20 mpg out of his Scrambler with this set up?:ZZZ: My stock 83 Scrambler (258 with computer controlled carb, T5, 3.31 gears and stock tires) gets around 22 mpg on the highway at 65 mph:thumbsup:. I beleive if this works you would be leaing out the mixture going into the engine, go too lean and you melt pistons. I think the stock computer controlled BBD carb does a good enough job (IF it is working properly) of optimizing fuel management on the 258. I bet when I swap to the Mopar MPI I will get less MPG:(
Not one clue. Depends on what's going on in the jar in order to generate the gas. Might not be very much.
The quote you have of mine is not meant to imply that this will require a lot of additional energy/load on the engine, it's just pointing out that what it does require is additional to normal running on gas, not just free because the alt is "producing electricity that doesn't get used"
Eric,
i hope you don't think i was busting your chops or anything i was just wondering if you or anyone knew. i hope it didn't come across wrong.
Any clue how "Tom" did over time?
If there's any interest I've got some links to guys that have isolated voltage/heat issues with their HHO generators and shown them on youtube.
I remember keeping a link er: hydrogen embrittlement, or some how hydrogen affected metal surfaces but wasn't something I spent too much time on.
Have exhaust, clutch and fuel tank issues 1st.
