- Biloxi
- MS
Didn't the guy that posted this up say he was getting 20 mpg out of his Scrambler with this set up?
My stock 83 Scrambler (258 with computer controlled carb, T5, 3.31 gears and stock tires) gets around 22 mpg on the highway at 65 mph
. I beleive if this works you would be leaing out the mixture going into the engine, go too lean and you melt pistons. I think the stock computer controlled BBD carb does a good enough job (IF it is working properly) of optimizing fuel management on the 258. I bet when I swap to the Mopar MPI I will get less MPG
