I got an 8!
AW COME ON CRASH
Cooties on a Scrambler?--Is that the reason all you Toy guys hide over in the corner at the campsites?:rolleyes: -JC
Re: AW COME ON CRASH
You know the old wise tale "cow tippin", wel, we sit there and plan out "jeep tippin", figured your rigs were better traction for us on your sides :D :D
LOL
You have to keep up with them first:rolleyes: Hey by the way wasn't that your rig laying on it's side with the Jeep behind it getting ready to crawl over it;) Naw i must be thinking of some one else-LOL-JC:D
Re: LOL
Man, that bad jeep knocked me over :D
WHAT JEEP
Aren't all of them bad?----:cool: ------Guys for those that don't know Crash has one of the nicest,dare i say Toyota's that i've seen.Sweet rig and he wheels it hard and i'm sure it's just about bullet proof after seeing the work that he did on that Scrambler-JC
Re: WHAT JEEP
mulescj8 said:
Guys for those that don't know Crash has one of the nicest,dare i say Toyota's that i've seen...I'm sure it's just about bullet proof after seeing the work that he did on that Scrambler-JC
Right, that means that it's time for the next project!!!
*in that nagging, quiet-but-annoying back-of-the-head voice*
Scraaaambler.... Scraaaaaaaaambler... Scraaaaaaaaaaaambler
Vooooooortec.... Rooooooooockwells....
I can see it now. New thread: "zerotoHOLYSH*T!!" :D
Maybe I'll have to wait until I can get him a Postal :cool:
You guys are killing me.... Did I hear postal, thank goodness I can't shoot good or own any guns huh (can see the paper now, crash shoots own foot off)..
Actually, you never know, once my toy is as far as I can go, I might invest in a heep (ops, jeep :D ) and build a more mild rig, but who knows, I might even fall off the deap end and build a full tube chassis, heck, I dunno, heck, lets go wheel....
I will have to send you the guys the link when I go and cut my rig up and you can't watch the mess...:D
When can i expect you?--I'll be at Windrock the 1st of November-See what your missing -lol-JC
What's going on at Windrock on the 1st??? Don't hold out on us here mules! :D I'm there if Crash is!
WINDROCK NOV 1ST
Plum Crazed Jeep Club is having a Toy Drive on Nov 1st they are meeting at the Midway Drive In and after the festivites they are heading to Windrock for RIDES!- go here www.sceniccity4wd.com click on the events page and you can get the details there-JC:D
Up Date!
Well I decided not to pull the engine untill spring.Ran a compression check and cylinders 1-3 range 145 to 150,4 125 low but doesnt seem to be a real problem yet,5 and 6 145 to 150.Also pulled the valve cover and replaced the gasket since it was leaking oil badly.Had to clean the PVC valve as it was clogged.Seems to idle very smoothly and doesnt choke at high rpm.Since the valve cover was sealed poorly water got in and made the upper in side of the valve cover a mess.Tested the oil to see if the water was else were but so far it seems ok.I'm planing on draining the oil soon and putting fresh oil in.
I need some help with my belts it should be obvios from the new pictures.The power steering pump sits way too far forward and I think its because of the bracket that it is mounted to.From what you guys can see from the picture is that the correct bracket?What can I do to remedy this as it is going to wear out my belts quickly.
wrong pulley
That's the right bracket from what I can see, but it looks like the wrong pulley. It should sit closer to the pump and I'm fairly certain that it should only have one pulley on it, there's no reason I can think of for two pulleys on the PS pump.
Take a trip to the yard and look for one that sits closer to the pump and swap them out. Measure the gap between the two so you can check the one in the yard before you pull it, that's the kind of thing I would forget to do and I'd come back with the wrong one :D
I concur...
I agree with Walton. I think you have some sort of hybrid pulley on your pump. I think if you changed that out you'd be good to go...
Bill
Did your 8 have the smog equipment on it? Because that looks exactly like my set up. My Jeep had the smog pump but I don't run one now. I will try and post a picture of my set up in the morning.
Muger
UP DATE!
Well I got a small update my father and I finished spraying por15 on my jeeps underside.My father started striping the paint tonight and I'm going to sand down the inside and spray por15 down and then apply some hercu liner.
attachment.php
