IAFFCJ 81 Scrambler
With a new plan to get the console and dash painted i now have
a deadline so I tried to get some more on the console knocked out. The storage area is skinned, I have modified the atlas sifters to get them over to the pass side so they don't interfere with the trans shifter. Also have about 80% skinned out and the CB and GMRS radio are mounted. Need to finish skins, route cables for shifters, build lid for storage area and figure out a cup holder they we should be ready to ship off to the paint shop.
Love the way your console is coming out. will the storage space be tall enough for an arm rest? :wave:
Thanks You. Yes the storage are will be the right height for an armrest. It will need a cushion I just need to determine how thick.
Still working on finishing up the console so it can hopefully go to paint next week. After trying to make a lid with just a hammer and a vise the frustration level was getting to me as they looked like poop each time I tried. So today I used some scrap steal I had lying around and a couple hinges from the hardware store i attempted to bake a sheet metal brake. While i was successful in making one I have figured out why most brakes are limited to 22 gauge. I have used 16 gauge for the console and turns out that the brake I built was up to exactly two bends of 16 gauge before the hinges bent too a point that it needs to be repaired. However lid for console made so all and all success.
Need to fit one panel for the interface between the console and the dash and then fit the cup holders. I have 3 different kinds coming as the fist attempt the order was incorrect. As long as they will hold a yeti they will be good. Once I get the cup holders figured out off to paint. I am going to have a pad for the top of the lid made by the upholstery shop down the road to finish it off.
I’ve got a brake you could use. I think it’s a 24” one. Let me know if you could still use it.
Thanks John. I should be good now. When I get to building inner fenders I might just take you up on that.
All I can think looking at that console :headbang:
Awesome stuff man!
Before i send the console out to get painted I wanted to be sure that all the cables for the transmission shifter and atlas would route the way I thought they would. Guess it was a good Idea as I needed to clearance the storage area to make the transmission shifter work and the atlas cables will need to go through a very different area than fist thought. Original plan was to use the holes in the original tunnel cover but they will not be used so I am going to close them up to try and keep as much grime out of the console as I can.
I have also been ordering parts pretty regular in the hopes to get this thing to a point I can start it.
Radiator with electric fan arrived.
Picked up the hoses that JeeperDD used on Dad's jeep so should be good there.
Also picked up what would normally be a transmission cooler in front of the radiator that I am going to use for Power steering fluid.
Found some 4in tail lights that have reverse lights integrated in them so I wouldn't need and additional light in the back.
Still shooting for the console to be ready for paint by Sunday so I can move on to other things.
What about the Atlas cables made you change the plan? What were the original/new plans there?
Originally I was planning on running the cables for the Atlas through the hole in the tunnel cover where a normal shifter would come through. The stiffness of the cables made it impossible to make the bends that sharp. The cables will need to go through very close to the fire wall to make a gentle turn and work where I have set the shifter handles. I decided before I made new holes I should take another look with fresh eyes in the morning. I will try to get some pictures tomorrow to help explain it better I apparently missed those pictures today.
Just finished reading through your build. The custom fabrication on your build is amazing.
Thank you. Been a long road. Hope to get to the run and drive things soon.
