In need of a good shop East of or near Raleigh
chappellheel
Nashville
Howdy friends! Took my 8 in for some light repairs and aterwards found that she now wanders awfully bad. Please recommend a good shop if you can. Thank You! I appreciate it greatly. I'm missing my jeep.
Not east, but a bit North, Independent 4x just north of Richmond can handle most anything needed to get it right.
What did you take it in for? It may be something simple you can fix yourself.
Wandering is usually due to something being loose or worn out. If you start the Jeep (if it has power steering, otherwise it doesn't matter) and have someone lightly rock the steering wheel back and forth just enough to load it up while you watch the front end/steering links, whatever is loose/worn out will usually reveal itself.
Depending on what the other shop did, they may not have tightened something up enough and I'd want to check that out before you drove it to any other shop.
There's a shop near Wilson that does "off road" work. Mostly I just see pics of lifted trucks but it might be worth a shot. Down East Off Road, I think is their name.
West of Raleigh there's quite a few folks that could help out.
Could be as simple as adjusting the lash in the steering box.
As BW mentioned check some basics. Something as simple as low or high air pressure in one tire as compared to others can make things interesting
I really appreciate all of the advice. Thank Y'all so much. I'm going to take a look myself b4 taking it in. My jeep has never been down since I've had it, TYJ. I am extremely blessed. Need to get her back on the blacktop asap.
