The Battle
This torque arm bolt fought and fought but I won the battle.
Today I got the drivetrain completely mounted and it was a bear. I ended up using a cherry picker to lower the transfer case while pulling backwards and to the drivers side with two ratchet straps while I had the motor mounts placed but loose. Finally getting it all lined up and tightened down was a rewarding feeling.
Is it always this tough? Also had very little wiggle room with the skid plate to frame. Seems as if the frame has contracted slightly and I ended up using a bottle jack to push it apart about an eight of an inch and the bolts slid right in.
Then I learned a lesson, if your going to install a new oilpan gasket you should probably do it before you put the motor in. The passenger side motor mount is in the way of one bolt and getting the pan out wasn't happening without removing the mount, not to mention lining up that gasket while upside down is a less than idea situation. If I had it to do over again I would have put the motor on by stand and flipped it and it would have saved me a few cuss words. I got it done though.
One question for you guys though, this timing chain looks quite loose on the bottom side. Is this normal or do I have problems?
I can move it about three inches and this doesn't seem right.
I also sandblasted some parts and painted them yesterday. I love this little blast cabinet. Beats any other way of cleaning stuff up. So quick and easy. I did go and get a different siphon gun for it though from northern tool. The one that came with it from harbor freight wasn't doing it anymore and the difference is night and day.
I am attempting to paint and clean up all the accesories on the motor while using up all the paint I have on my shelf which means its a rainbow of parts on the motor but I should be the only one to see it. I had a bunch of different engine enamel from various projects that I needed to get rid of.
I've learned a bunch on this project and the most important thing I've learned is that when you have a project like this you have to set short term goals and make list of things to get done or you end up getting frustrated and moving to three or four different things that are all incomplete and it gets quite overwhelming. I have been making some short punch list for every day that I'm available to work on it and it has made me much more productive.
That's all for today. I should be getting my rear axle back from the sand blaster on Tuesday and will have a rolling chassis again this week so I will post some more pics.
