Ok I didn't have much time tonight as I had to spray the nasty spring weeds in the lawn, but I did accomplish a small project today.
I had a trans leak (Torque Flight 999) since I pulled this motor and assumed that it was coming from the pan gasket because that's where it was and I set it down in the floor pretty hard when I pulled it the first time.
I think the TF999 is the same body as TF727 and TF904 so the repair should be the same for all.
Upon further inspection this is the culprit.
So here we go. Shift selector shaft seal is leaking.
First loosen nut on throttle kick down cable and pull it straight up and off. Repeat for gear selector lever.
Now you have exposed the seal.
I pried the seal out very carefully with a small ended screw driver. It actually popped right out without much pressure.
This is what the old seal looks like.
New seal
I picked it up at autozone because they had it in stock at the store near me( I usually never go to autozone and prefer napa or advanced auto).
Autozone part number is 8609
New and old
Placed new on the shaft and slowly and carefully pushed it down.
Used a 13/16 deep socket
Continued in a minute....
Sent from my iPad HD
