OK,with the frame welded up, i moved on to the clutch,pressure plate,and throw-out bearing
I removed drive shafts,trans and transfer-case,bellhousing,and clutch assembly
1- i found i had a separated motor mount on the drivers-side
(found this when trying to support the motor to remove the trans)
2- found "NO" pilot bushing in the end of the crankshaft
motor had 4000 miles on it when i bought the jeep,so must not have been replaced
when motor installed
3-found clutch fork had worn into front bearing retainer
perfect fit !!
look at the differance in the two clutch forks ,the one i am going to use on the left, has little
pins for the bearing to clip into so the fork cannot slide down and wear into the retainer
anyone else ran into these problems
