Jims "repair"-ation thread
"Ok , I am going to try to stop parting jeeps for awhile so I can maybe get this back together"
James, are you feeling okay??? You should should consider going to the doctor! :D
On a serious note let me know if you need some help wrenching and I'll drive up for the day.
Little more done, body mount welded and tub off to be painted
The green you see is EASTWOODS internal frame paint, thought it couldn't hurt (??)
Sprayed it in all the channels
I am going to paint the bottom, cowl, and fenders with
Started on it today ! It's thick !!
Putting it on with a brush ( like a caveman)
More pics as I get more done !
Thanks for watching
Thanks for sharing the journey with us... :thumbsup:
I am curious to hear about your experience with the Rust-o HP Protective Enamel. Have you used it before? What did you think?
thanks,
z:ZZZ:
I have not used it before, I was looking for something that I could apply that will be durable and possibly clean up and be touched up easily(it comes in a spray bomb also)
Another member here has used it and approved of my choice and the man that did my floor pans and wheel wells has done body and paint for his whole life approved and he is 70
We will see !! Thanks
Jim, what is the gray? Is that just primer or some type of prep/undercoat?
Also, is the black stuff the final coat or will you cover that with something else?
The gray is a primer that my body guy applied for me when he was finished doing my repairs
I had wire wheeled the entire bottom and the new panels were bare metal so he shot the whole thing
I think it is a 2 part epoxy primer with a hardener in it
The gloss RUST-O is the final application
I did the bottom of my fiberglass CJ-7 body with the gloss black Rustolium...it hasn't rusted yet! It did cover well.
Wait what?...were you expecting a fiberglass body to rust? :thumbsup:
Looking good :thumbsup:
Please tell us the details.. How much did you use? How easy was the process? 1 coat so far? Your best understanding todate....r would you use it again? Whatdayathink?
z :ZZZ:
So far , so good !!
Almost a half gallon , one coat !
Just a little heat to help dry !!!
z :ZZZ:
Spoke with another member (va beach!!) and he has used it and he said it takes longer to cure than most , but will eventually be hard as rock
