Jims "repair"-ation thread
i have started scraping the bottom of the tub,i am not having fun
the undercoating in hard as rock in most places,it looks worse than it is,all the supports are solid with only one body mount to repair
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
more pics and some progress ,once i get the bulk off,i will get it outside and soak it down with degreaser,and then wire wheel the pi$$ out of it
any suggestions ?? (other than give up!!)
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Have you tried paint stripper. It seemed to take off about any coating that was on mine. I used "Aircraft Stripper" followed by a good de-greaser and pressure washing to remove any residue. If you go over it good with a leaf blower right away you can avoid or end up with very little flashing.
Stripper?
How well does the drimmel tool work? I've seen that on TV, but didn't know how well it worked in the real world. Looks like too small a tool for that job maybe.
KK
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
The heat has kept me busy and i spent some time parting Dan's jeep out for the axles, tub, rocker knockers,full soft top, cheifwahoo, rear cross- member,AGR steering box,(w/HD mount)
Borgeson steering shaft
I had to have the axles overhauled ,but they have 4.56 gears,ARB's front and rear,warn internal spine kit and HD STEERING linkage
I have also added some currie HD shackles, and greasable poly bushings
I went ahead and installed the axles with new u-bolts and currie HD spring plates
I am finishing new brakes in the rear tonight during the bad weather
Pics coming in a few minutes
Jim,
I think when we were on the phone about my a/c problems in Texas, you told me I was screwed because I had gone ahead and done the frame off.. I didn't realize that you'd come to that conclusion from experience ;)
We're nearly at the same place in our resto.. wanna race? ;)
Thanks all !!
Just a few more pics of some more minor progress
Cleaned up a old set of hoses
Got my shocks back on
Converted rear yoke from straps to u-bolts( u- bolts from ford application)
http://www.jeeptech.com/axle/aub.html
Early model u-bolts are not wide enough
AGR and HD bracket installed
Had to use washers to get sway bar links correct with the new spring plates
I LOVE TAPATALK !!!
Ok , I am going to try to stop parting jeeps for awhile so I can maybe get this back together
Tub is on so I can position a rear body mount and tack weld it in place
Then I will pull it off the finish and paint the bottom
More to come as I go,
Wish me luck y'all , I can't wait to drive this again !
