regular guy
- Cameron
- NC
1983 with a 4.3L Vortec, T-5, Dana 300, 4.56 gears with ARB Air Locker. Dana 35 up front and 44 in the rear, 255-85-r16's. Came with half hardtop and bulkhead, full Kayline softop, full hard doors and half soft doors. Paint is original as are all the decals. On to the pictures.
Apparently the engine swap was done by an engineer. There are a bunch neat little things on this jeep which smack of someone pretty freakin smart who thought it out. These include:
Air Tank for the ARB's is the front bumper.
Vehicle wired as a tow vehicle. Switch on the dash for run/tow turns lighting system into a trailer wiring system.
front AND REAR warn hubs. Just leave the rear in 4x4 when you drive and flip them to 4x2 when you tow. All axles disengaged.
Wiring harness was spliced wire by wire to integrate the 1994 4.3L to the 1983 Body. There's a check engine light and an OBD2 sensor under the dash.
First thing of many I did was replace the tailgate cables, swap over to the full soft top(thank you Walkerhound for the walkthrough of the early kayline install. I was staring at pieces until I found your instructions) And put the rear seat that came with it in so its more family friendly.
Anything you can think of good or bad that I didn't mention would be greatly appreciated!
