- Dexter
- MI
Got a pair of the JW Speaker 8700 J2 LED headlights to swap into the Postal to replace the Delta H4s. They instantly looked yellow as crap once I upgraded the front aux lights to LEDs.
Wiring (they no longer offer the H4 plugs in DOT approved version for the US) and mounting in the headlight buckets are the two issues.
Mounting:
You pull the stock stuff off, one screw below the headlight surround, three holding the bulb in with a trim ring and four holding the bucket in the grille.
Even though the bulbs I pulled aren’t stock, you can still see how the rear shape differs considerably with the heat sink fins. That means...
...it’s chop chop time.
I used the step that is built into to bucket to “lean” my cutoff wheel on from the back. It ended up removing more than is really needed but it opens up the most area for cooling.
I have to admit, I was thinking I was going to have to learn to like these. I always had an issue with the hard “step” in the profile of the Deltas and these look 1000 times better. The black guts blend and match the black on the bumper and other LEDs. Kept the other Delta in for a true “before and after.”
Loving it! Next one to go in and then swapping on H13 pigtails.
Mounting:
