Let's see... where did I put that sawzall?
Manhattan
Atlanta
GA
I kinda knew I'd be doing this - cutting the new tub. In a perfect world, I'd have done this BEFORE paint. But, since I'll just be removing some metal, touching up the edges will be fine. Where I blew it wasn't the body - it's the bed rock rails, which are integrated into the rear bumper, tied to the frame and cage... yeah. They'll be cut and re-capped ON the Jeep.
I've got to get some TJ flares to see where they line up - they'll determine the cuts.
As you can see, not a lot of choice, well... I could go to 33s ;-)
(this shot is of the passenger side; rear is to the left... the rock rails make it look like the rear is to the right)
Is this only on full compression? If so, you could install the MORE plates that move the axle forward 1". That and spacing your bump stops down a bit might solve the problem. Mine only rubbed on the rear, the front was no problem. But I cut both sides to match my flares.
What Randyzzz said, I would try his two recommended options before cutting on the tub!
mmmmmmm i like the sawzall it's my friend:drool::drool:
