My $300 Winch
Major Jack
Zillah
Wa
Was able to open up my new, used 8274. Came apart really easy and looks new inside.
Though it wasn't leaking oil, I went ahead and ordered a new lower end kit. As long as it's apart, decided to replace bushings n seals.
I'm going to leave the top end alone. Am looking at putting a fill and drain plug in.
Warn calls for 6 oz. 30 weight oil. I have read where others are using 90 weight, a mixture of regular oil and Mystery Oil and one guy ATF. Any suggestions here? I was thinking about one of the Lucas Oil products. It seems to stick to gears a bit better than regular motor oil. Was thinking it might help the caged roller bearing live a bit longer.
I'm going to replace the solenoid pac with the single from Albright. Seems to be a real popular conversion. You can mount it on the winch or under the hood. I'm thinking under the hood with a inside control panel and the plug in control out on the winch.
I was able to get two Albrights for $125 plus freight. One was for a spare. Now, not so sure A spare is needed. Might make the second available for what I paid for it. That's about $40 off retail.
Question?
How much did you budget for the "rebuild". One has come up for sale near me for $250 (way less than these usually go for in KS). Waiting to hear about condition, ect. Was wondering how much I am looking at to refurbish? I would assume new solenoid and synthetic rope.....So thats $250 to start.
Keith
OOPs, That was $125 Each on the Albrights.
Buy it for $250 if everything looks like it's all there.
Got a picture of it Keith?
There are some excellent writeups available. I have 5 or 6 bookmarked. Just Google Warn 8274 Rebuild. They would give you more insights into what to expect.
What I did when I bought mine was. Look at the case for cracks, pulled out the know for engaging and disengaging the drum, turned the drum by hand. Water inside the case will make them seize up. Still not a deal killer as they can be freed up.
Really, if you can buy for $250, I would buy it.
For $250, buy it. After looking for misc parts for a while, I'd bet you could part it out and double your $.
I bought a total basketcase and it's now on the front of a Jeep working. For 250 unless a case is cracked or it is missing major components buy it.
Jack, what did you do with your factory solenoids? Also, where did you get your Albright? I'm debating on which to use on one of these project winches I picked up not too long ago (was missing solenoid pack).
Called the minute I saw it on CL this morning. Guy called back about 20 minutes later to tell me I was #2 in line. First guy driving in from 3 hours away to pick it up. :(
Seller told me he thought it was complete, but would require a complete restoration to make functional. Hoping he calls back cause #1 fell through, but not optimistic.
Keith
Where does everybody get their 8274 parts?
Sent from my Illudium Q-36 Explosive Space Modulator
I got my lower kit with both bushings and seals for the drum off Amazom.com They had about 17 parts for a 8274 listed.
Seems the sealed bearing and oring for the shaft that engages the winch are available over the counter. The Albright solenoid is the expensive part. About $160. However, instead of worrying about 4 solenoids and having to figure out which one is bad. You have just one heavy duty
I was asked what i did with my 3 good solenoids. Still have them. There are sources for the Albright on the web. I can't say where i got mine as a friend got me a deal.
The Albright numbers are- DC88 or DC88P
The DC88P is more warterproof than the DC88.
I have an extra DC88P coming. Supposed to be here tomorrow. I ordered two thinking I would need a spare. I have talked to a couple guys who have ran them for years and have yet to have one fail. $125 plus shipping in a Priority Mail prepaid box. About $10.00.
The lower end seal kit, the plastic solenoid cover, and the plastic harness receptacle are still available over the counter. The motor is too, although pricey. Many aftermarket motors exist, although I can't vouch for their quality. The metal harness receptacle is a simple 4pin round trailer plug. And, Warn will send replacement decals free if you call them.
GoWarn.com and Warnserviceparts.com seem to have good parts selections...sit down before checking the prices, though.
Lots of times there are parts available on EBay from guys parting them out.
Albright solenoids arrived. These are a quality unit. They are heavy duty. Must weigh a lb. each. Gonna like having the ease of wiring. I'm probley gonna moumt it under the hood with the stock Warn controller in the cover. Looking at a in the cab panel with an on/off failsafe switch, power in, power out.
If you are intereste, I hav an extra Albright. Thought I might need a spare. Doesn't look like that is the case.
Summit racing has about the best prices for 8274 parts I've found. Go to warnserviceparts and get the part number you need, then plug it into the search box on Summit.
Got the new seals installed. Put zerk fittings in the right drum cover to lube the bushing. For lube in the gear case, I used a mixture of 4 oz. Of 30 weight along with 4 oz. lucas Heavy Lube. This is the stuff that climbs the gears and sticks.
Cleaned up the armature and brushes with fine emery. Powered it up in forward and reverse. Ran great.
Now, I have to make the bumper work. After making a few measurements, I have determined the bumper was for a middle 80's Chev. Gotta make it fit my 97 F250.
After the bumper and winch are mounted. I will decide where the mount the Albright solenoids.
