Major Jack
- Zillah
- Wa
Was able to open up my new, used 8274. Came apart really easy and looks new inside.
Though it wasn't leaking oil, I went ahead and ordered a new lower end kit. As long as it's apart, decided to replace bushings n seals.
I'm going to leave the top end alone. Am looking at putting a fill and drain plug in.
Warn calls for 6 oz. 30 weight oil. I have read where others are using 90 weight, a mixture of regular oil and Mystery Oil and one guy ATF. Any suggestions here? I was thinking about one of the Lucas Oil products. It seems to stick to gears a bit better than regular motor oil. Was thinking it might help the caged roller bearing live a bit longer.
I'm going to replace the solenoid pac with the single from Albright. Seems to be a real popular conversion. You can mount it on the winch or under the hood. I'm thinking under the hood with a inside control panel and the plug in control out on the winch.
I was able to get two Albrights for $125 plus freight. One was for a spare. Now, not so sure A spare is needed. Might make the second available for what I paid for it. That's about $40 off retail.
