So that's what it looks like under all that oil....😬
Yep
I found one spot on the front I still need to clean, to make sure the new valve cover gasket works.
I did a little work this weekend, not too much, valve cover gasket issues
On the intake/exhaust manifolds, the tap worked, I was able to re-thread the intake manifold, big sigh of relief. The oil pan drain plugs work. I will have to see if I need to install washers after I get the engine fired back up, but I believe the end of the plug seated firmly against the interior seats in the manifolds should seal the holes.
The exhaust manifold on Josh's Scrambler had issues, too. One stud to hold the down pipe to the manifold was missing, the other one has stripped threads at the top. A bolt fixed the missing stud issue, and I used a steel spacer to get below the stripped threads on the other stud. I tried to heat the stud with a torch to remove it, no go. I didn't want to break it, I've done that, it's real fun drilling out busted studs in the exhaust manifold.
The other issue - the down pipe "flare" did not fit tight against the cast "doughnut" on the bottom of the exhaust manifold. On my two 83's, the pipe fits tight to this doughnut and seals. On this '81, it was a loose fit. But, I had a "gasket" thing for this issue that I previously bought and never used. All these repairs should quiet this Scrambler down considerably.
Picture of the "gasket" and studs.
I had previously bought and (attempted to) installed a thin, cork gasket to the aftermarket aluminum valve cover. I used a NAPA/Fel-Pro gasket Part #VS50244C. I really liked this gasket, and it only cost around $10.00. But, I tried to glue it on with aviation sealant, and it never would glue down tight to the valve cover, it wanted to squirm out. I removed the gasket, then attempted to glue it to the valve cover, but the two adhesives did not like each other, and made a big goopy mess.
After about two hours of clean up, I had the valve cover ready for another gasket. But, no stores had the above referenced gasket in stock. The only gasket I could obtain was a Fel-Pro VS50244R, which cost like $45.00!!!!!!!!!!!!!!
I went ahead and bought the expensive gasket to try out, here is what it looks like:
It is some kind of cork/rubber composite, like two seperate gaskets, bonded to an internal steel strip. The instructions say not to glue it to the valve cover, so that is what I am going to attempt. I do like the internal metal strip, once you install the valve cover bolts through the gasket, the steel strip keeps the gasket from squirming out.
Once I get the engine up and running I will report back on this gaskets performance. If it leaks, it will be simple enough to remove it and install a more conventional cork gasket, like I installed on my red Scrambler's 4.2 (with aftermarket aluminum valve cover), 28,000 miles with no leaks, knock on wood
That's it for now
