My Scrambler Substitute
Looks great Ted and I really like the Jeep button on the steering wheel. I will have the speedometer adapter by next week and they took back the Ford unit (their records show it was supposed to be the GM/Chrysler version. They just sent the wrong one. I still need to pick up a fan motor, too.
Looks great! Like the custom horn button!
Great build Richard, I'm lovin that rig. It looks like the Commando is wider than a Scrambler? How difficult would it be mounting a Commando body onto a Wagoneer/Cherokee frame? I like the D5 grill addition, it's the second one I've seen and the rounded nose is a nice little custom look.
Wm
Wm
Thanks! The Commando has been a joint build with Ted Wendell and he deserves most of the fabrication credit. I come up with the designs/ideas and he works the magic (after giving me a lot of dirty looks!). The goal was to build a one-of-a-kind trail Jeep that can also be driven on the street. So far, it gets a lot of attention every time I drive it.
The Commando body is the same widt as a CJ, in fact the pre-AMC CJ front clips are often swapped onto the 67-71 C101 Commandos, which is what mine is. AMC produced the C104 (104" wheelbase) in 72-73 and the AMC era CJ front clip can be made to fit. I have the exact same FSJ axles under the Commando as Ted
and I put under my Scrambler (he built a lot of that one, too). The wider axles, flairs, SOA lift, and big tiresare what make it appear so big.
Very cool rig!
It's no secret that I'm still in mourning for parting ways with my Commando. Lol
Hmmm you know what this rig needs . . . One ton axles!
Pics to come! :)
Well, have not updated my build thread in a long time so thought I would add a few pictures before Sean (CJ ATE) starts posting the one ton swap (more on that later). In looking through the post I also realized I had never posted pictures of the completed project so here we go:
First a few "glamour shots";
As a recap my "Scrambler Substitute" is a highly modified 69 Jeep Commando with the following; tricked out 4.3 V6 (300 hp), TF999 auto, Dana 300 with 4:1, SOA with narrowed J10 Dana 44 in front (see my thread on "don't use a Wagoneer front axle" :rotfl: and 89 FSJ Dana 44 with 2" spacers in back, lockers, 3.73 gears, Michelin 11.00R16 XZL Military tires (39"), DJ postal Jeep grill and hood, custom tube doors, modified Scrambler roll bar, metal bikini top (chopped factory top), and a lot more.
The Jeep is a blast to drive and gets gobs of attention everytime I drive it. It is really funny watching even the Jeep guys try to figure out what it is. I have loved the drivetrain set up, the hopped up 4.3 moves the Jeep really well and the 3.73 gears with 39" tires means it will cruise at 80 mph with no problem and is stable as it can be.
Now for the trail shots and information. This thing has been awesome on the trails and I LOVE these tires! The 11.00R16 Michelin XZL was the Marine HUMVEE tire but is no longer available (I have a second set stashed in the basement at work). The lugs are super deep and self cleaning so it does well in the mud.
The rubber is VERY thick so I air down to 2 pounds (could run them at zero) and the narrower width of the 11:00 gives them great bite.
However, these tires are HEAVY, really HEAVY! One 11:00R16 weighs as much as all 4 of my 35x12.50 Mud Terrains. I haven't broken an axle yet but know it is just a matter of time so I decided a set of one ton axles were in my future. After a lot of study, measuring (you know me) and talking with other people I chose a GM 14 bolt rear with 4.56 gears and an ARB for the back and a GM Dana 60 with ARB that has been narrowed to fit the Commando/CJ frame width for the front.
Talked with Sean (CJ ATE) at Oak Ridge last Fall about doing the swap so break out the :popcorn: because Sean is THE Man!
and is the the man
I've been in love with commandos since the day I saw "this" jeep at the meet and greet in Richmond
Rich dropped the Mando off a lil while ago. We went over what he had in mind and got to work.
Out with the old dana 44s.
Custom narrowed dana 60 going in the front and 14 bolt in the rear.
Prepping the 14 bolt, setting pinion angle,welding on perches,shock mounts, etc etc.
No turning back now! LOL
Setting pinion angle and checking mock up.
OK math checked and rechecked time to throw some sparks!
Housing is done time for the ARB.
ARB in patteren and backlash set
Front axle back in 35 spline outer stub shafts and new Warn hubs installed. Sent lons side inner axle off to Moser to be cut by 4.25 inches and resplined.
Goody box from Moser got here today!
Long side of the axle back together.
Mounted these monster military Michelin's that Rich loves. Cool tires and DAMN they are heavy! LOL
View of rear track width in relation to the flare.
Rear disc brakes clear the rims. Its close but they clear by about 3/16".
Compressor for the ARBs mounted.
All the hard work is done. Down to the fiddly bits . . . Yes i said fiddly bits. Blame it on watching too much BBc Top Gear I guess. LOL
This project has been rather fun Rich is a great guy and Im looking forward to seeing what this rig can do in a couple weeks.
Tedd if you can hear me up there Im cutting Rich dirty looks now in your honor.
More to come.
The big question....will it be ready for next Friday morning? It looks like it will. Great work Sean, I could use a welding lesson from you.
I :bow: to the awesomeness in this thread and the recent work.
No rush, John, still have seven days! Lol
Sean's work is outstanding (of course you already know that if you've ever seen one of the rigs he has worked on/built) and Ted would be proud! I am really looking forward to trying out the ARBs and one tons at Oak Ridge. I love my military tires but they are extremely heavy and way beyond what a Dana 44 should be turning. Have been babying them ever since I put them on and I haven't broken anything but it was only a matter of time. The 44's will survive much longer under my daughter's CJ7 (that's a winter project).
More mods coming in the near future on the Scrambler Substitute,fuel injection and a combo cage/Scrambler role bar (still working out that design), but 4.56 one tons with ARB was first on the list!
You guys stop bothering Sean, he's busy! :D
For those of you not familiar with the 11.00R16 Michelin XZL it was used by the Marines on their HUMVEEs until about 10 years ago (along with the XL which has a different tread pattern. It is listed as being 38.5" in diameter but is 39" tall (particularly on something as light as a Jeep). All the other Service branches used the a 37" tire on a 16.5" rim (you see them on ebay all the time).
Here is a comparison of the XZL to one of my 35x12.50 Mud Terrains;
That's a XZL in the top picture, XL in the lower. Here is a better shot of the XL tread pattern;
The Marines were required to give up their taller tires (they also had used a 11.00R20 version on their deuces that was 42" tall) and surplus their inventory. The Vietnam era M715 used the same tire size so those of us with M715's scrambled to grab what XZL's and XL's we could find. I picked up a couple of sets for my M715 but moved up to the 11.00R20 when I did the one ton swap on "Big Cheese", my 6.2 diesel powered 67 M715.
Here's my M715 with the 42" 11.00R20 XL's
I decided the 11.00R16 XZL's would look great on my Scrambler Substitute and the additional height would be an asset on the trails. I was right. :rolleyes:
Here is a shot of three of my four Amigos;
Those are 42", 39" and 35" tires. Around my house 35's look pretty small! :usflag:
Nice rigs! I feel like 37's are the new 35's now. Or maybe it's just because I hang out with friends runnig 40+" tires that my 37's feel small. It's like buying a big screen tv. You just can't go back to a 32" once you watch the movie 300 on a 60"! ha.
Thanks for the props guys!
Yes it will be ready for Oakridge along with the other 3 I have here.
My Scrambler will probably still be leaking oil and the belt squeaking but the rest will be ready. Lol
Rich stopped by today and he's happy so I'm happy.
Hey Rich I will be ready to do the cage in a couple months so get a rough idea of what ya want and we get something drawn up in Bend Tech.
Wow! I've read through the entire thread and it was nice to see you catch up with everyone hear. I'm sure your friend Ted is proud that you've carried on with all the work you both put in to this project. Enjoy it and all the good times that bring friends together Jeep'n.
