Mystery box on RH front fender?
rreed
Anytown
TX
Hey guys, new to 1. all complete factory original stock Jeep 2. 1981 Scrambler. I'm about to start restoring this one as the PO had torn it down for restore but never finished.
I know the Motorcraft ignition module, it's in one of the boxes of parts. But there's another smaller mystery gray box w/ wires coming out of it that looks like it would mount to the passenger/RH fender. It's some sort of epoxy sealed back/non-serviceable.
What is this?
a picture is worth a 1000 . . . .
I have an 83 and don't have anything like that. I did have a battery isolator for using two batterys that was mounted on the right fender. Maybe it might be something like that. Get us a picture and the more experience guys on this board will be sure to explain it.
I know what your talking about. It has something to do with the carberator. Mine would shut off when cold and I had to give it a whack. I never could find a part store who knew what it was.
Well that's part of the mystery--my carb has no electrical connections. Plus it will be getting an MC2100 come time to fire over anyway; I'll be looking to strip it down to bare bones HEI/e-coil ignition/MC2100 carburation.
My money is on either a voltage regulator (but it has too many wires) or a brain box for the emissions system (to control vacuum relays, ect). Just guessing...but you got my curiosity up!
What carb is that?
The box looks an awful lot like an ignition box to me...
Maybe someone pulled the stock stuff (since it's in a box) and swapped on that thing instead? Show us the dizzy and any connections to it...
Also jscherbs question is a good one, what's it hooked to?
I have the same box on my 82. just pulled it today and haven't figured out what it affected. It runs the the ignition box and some vacuum relay at the rear of the engine ( Vacuum Switching Solenoid).
As soon as I can I'll trace out the wires. Distrib looks like basic/typical Motorcraft. That's another good question is that I've yet to be able to identify this weird carb. That's been another mystery but it'll get torn off and thrown in the trash for an MC2100.
The stock stuff is in a box as the vehicle has been torn down to rolling chassis/drive train for frame-off the PO never completed. Wiring for Motrocraft box is intact and still connected to everything. I doubt voltage regular--it's an '81 and alternator is a typical 3-wire Delco. Also too many wires for that(?).
I don't recall seeing any vacuum switching doodad on the back of the motor but the emissions stuff has been removed. The two CTOs on the intake (will also need help identifying that) are disconnected.
It is a standard ignition moudle.
I replace it with GM module (with all the upgrade of the ignition system).
BTW, I had it inside the left fender (driver side).
Avigdor
bigwalton said:
What carb is that?
Eric, That is the 1981 Carter BBD with out the stupid steper motor. The best year they made the BBD I think. I have mine still running strong.
TK
I plan to do HEI/e-coil (more commonly known as "HEI/TFI") so can I toss this mystery box?
Am I better off keeping this carb or ditching it for an MC2100?
Unhook it and see if it makes a difference, it didn't on mine when it was still "stock" looks like OEM crap to be!
I believe that is the California ECM that was added to the '81 and '82 rigs to make them compliant with Cali emissions standards. If you are located in California, you need this...otherwise, removal of this box would make your rig the same as every other '81 Jeep released.
Interesting thing that I have read (but not confirmed) is that the '81 Cali rigs had the pre-stepper BBD and the '82 Cali rigs had the stepper BBD. Also read (but not confirmed) is that this early ECM did not control timing like the final ECM that was released with the '83-'86 models...
I have an '81 that I believe originally came from Ca. It has that box mounted on the right fender. I have a Carter BBD without the stepper motor that works very well. I will try to trace the wires tomorrow.
Bob
That sounds like my setup too, but it's an '82. And my carter also runs pretty good. Only stalls on steep hills.
Is that your final answer?
It's an idle speed controller. Long story short, it uses signals from here n there to sense what's going on and uses the Sole-Vac solenoid on the Carter BBD to bump up the idle if necessary.
Short story long:
I had one on my 48-state '82, my wife's high-altitude '7 had one as well; I don't remember if my buddy's Californicated '82 had it or not. I've since removed the ones in my Scrambler and the wife's '7 with no ill effects (my BBD has no Sole-Vac unit anyway; she's running a Weber).
It has eight wires in a nine-wire plug: one to the sole-vac unit on the carb, one to a control vacuum solenoid on the back of the valve cover, one to the manifold heater relay, one to the coil negative pole, one to the thermo-electric switch in the air cleaner, one to the A/C compressor, one to 12v power, and one to ground.
If you're running the BBD with the Sole-Vac unit and want it to help control your idle speed at points of a) low ambient temp, b) A/C compressor startup, c) intake heater events, or d) low idle vacuum, then by all means, keep it. If, on the other hand, you a) don't have the Sole-Vac unit, b) don't have A/C, c) don't care if it works or not, or d) notice half the pins have corroded away to nothing (like on my wife's '7), then tear that sucker out. Feel free to trace the individual wires back to wherever they connect, and disconnect them there. One less umbilical draped across the engine bay. :D
I just did an HEI distributor. Had a mechanic do it and that little box is now gone. Cheers
Thanks for all the help, I now know a little more about late model Jeeps. Really, I'm doing HEI/e-coil hybrid ignition and an MC2100 carb so no little boxes matter. I just wasn't sure about this thing controlling or doing something that would have kept me from doing a hybrid ignition or 2100 carb.
