You really need to get either the OBDI scanner or the WinALDL to fix your problem. You need to look at the data stream and see what the ECU is seeing. That will be the best way for you to resolve your problem. Then you can post up the values and we can sort thru them to help you find the problem.
Just because I'm a retad.....do you blow through the TBI or the actual hose to check if it blocked?
