. Worked pretty good, this should help with the drag link angle. Also greased the tie rods (before I forget).
unfortunately this will probably be it till I decide on a motor and get the funds together to either get the 401 rebuilt or go with a Engine Factory 350 like I did on the cj7. Only other issue I could try to figure out is the brake pedal which you push down with about 1/2" play than 1/2" of brake and it's solid (can't push down). You can push the pedal down (1") and if you try to spin the tire the brakes are applied. This is with the power booster and no vacuum, linkage is not locked.
The one that came with MC setup
The one I painted and replaced it with. One rod helps to remove any additional problems. I used this bracket with the cj7 vanco MC setup and had a normal pedal. Did notice cj7 rod moves into booster approx 1/2" and the cj8 (with original bracket) only moves about 1/4" (after freeplay was removed) looking from inside cab at the fire wall hole.
Randy thanks on the compliment but more so on your brake writeup. Bought the first setup on ebay and didn't get set up for a year. Their's something wrong with the setup. I usually use vanco (he stopped making the booster setup) so I needed a good referral. Haven't put a vacuum on the booster or power for brake light (worry about that when engine is in) but got good pedal with your mc/booster set up. Thanks for the direction.
