New Brute Kits.. Kinda cool
Brutes freaking rule. Just the fact that a company even makes that kit gives me a warm fuzzy :bow:
Aqualu
Just an FYI.
This conversion can be done to any CJ or YJ for a lot less money with the Stock Tub and bed from AQUALU in Canada. In stock they have a cab for (about $2300) and a bed (about $2200) for standard & bob-tailed CJ-8's. Does not require stretching the frame. Install the cab & bed, slap on your preexisting 1/2 cab & voila ... CJ pick up.
I am, in fact, performing this conversion on my '83 CJ-7 to make it a short, very custom, flat bed. The only difference is that I must stretch the frame to atleast CJ-8 wheel base or the cab will hit the rear tires.
So far, my dealings with AQUALU have been outstanding. They have bent over backwards to help me with every little question/issue.
This whole thing only leaves me with one question though. If I stretch my 7 to an 8's footprint & make it look really good, can I atleast cheat a little & call it an 8?
mlg
mlg123 said:
Just an FYI.
FYI...The Aqualu tub is based on a CJ-10 tub (see my avatar), which has rounded rear corners. Some work will probably be needed to mount a Scrambler 1/2 cab, as they're based on using square corners.
Craig
1x1_Speed_Craig said:
Some work will probably be needed to mount a Scrambler 1/2 cab, as they're based on using square corners.Craig
True enough, but no matter what, if you're working on or customizing a CJ, it will require modifications. Some easy, some technical. My bottom line is getting a unique unit at as low a cost as possible. By going this route, I will save a huge amount compared to either purchasing an 8 or a $10,000.00 kit from AEV. And, the kit from AEV requires lots of work/modifications.
mlg
side notes
ah... Patience grasshopper, a half hardtop by GR8TOPS for the Aqualu shorty cab will be available later this summer. I'm going to try and make 1 top fit both the Aqualu stock shorty tub, a replacement for OEM CJ-8 hardtops, on an OEM body, CJ-7 body with the rollbar removed and also a YJ with the rollbar removed. All of these options would of course require a custom cage.
Aqualu is loaning me a stock cab and will arrive here next week. Very nice people to work with as they have been great to speak with and have a very quality product.
The Aqualu tub will work with an OEM Scrambler half cab right now but it leave a gap of about 1/2-3/4 inch all the way across the back of the tub where the OEM half top rises a little bit. When I make the new top, we will be redesigning the OEM bulkhead and it will be a custom bulkhead that will only work with a GR8TOPS half hardtop.
I spoke to them about possibly making the same type of cab based on A TJ door and a TJ windshield frame with a little bit longer than this shorty CJ box. Basically the equivalent of the brute cab but all in one piece and in aluminum. I really think that would be a good seller as even the buggy crawling crowd would buy that in addition to the people wanting to do a TJ based truck conversion. If you are interested in that, call them up and put a bug in their ear about it.
Side note, the cab will be available later this fall if someone wants to purchase the cab with a top.
Very cool, Matt. Can we exchange some measurements? I want to find out if the aluminum tub is the same dimensionally as the stock '10a tub.
Very cool project/collaboration, BTW.
Craig
Hey Matt,
I have a Bobbed Aqualu tub if you need it for mock-ups and stuff.
Carl
