New Guy Here....
Mntngoat
Fountain Valley
CA
new guy alert.
I've admired the CJ-8 for many years and now am looking to get one of my own.
Are there any links someone could post of what to look for or possible problem areas when searching for one. I understand most parts are still available.
I'm specially looking for a basic scrambler with 258 or 304 and 4 speed. Mainly just want to make sure it's got a solid body frame.
I anticipate it will need some work in order to make it road/ trail worthy.
Michael
Welcome....
Lucky for you, southern CA Scramblers will have less to no rust. There are some threads on here that go into a lot of detail on what to look for when inspecting a Scrambler. FYI, any 304 Scrambler will have had an engine swap.
First off, welcome.
I think you'll find the folks on here very friendly and helpful.
My .02 worth:
I can't really think of any good links other than this very forum.
If you are familiar with a CJ-7 - the Scramblers have pretty much all of the same problem areas. I would say just look for rust first and foremost. The areas just in front of the rear shackles can be a problem area for rust but can be real hard to see since most of the rust occurs on the inside of the frame and rusts out. It's a low spot on the frame and mud congregates there and holds moisture. Look around the steering gear box too. That is a spot susceptible to cracking especially if it has power steering. As John mentioned above, any V-8 in a Scrambler would mean it was swapped in. 258 inline 6 cyl and a 4 cyl (not sure the displacement) were the only two engines found in Scramblers. V-8 is not necessarily a bad thing if you know about it but not original nonetheless. If you find one, post up some pictures in here and the guys on the board will give you some good advise about it and if it sounds like a "fair" price.
Happy hunting!
Thank You. Looks like I'll be looking for one with a 258 CI engine.
Nice thing about being out west is the lack of rust but thats when you can find one. Most people out here are real proud of them and their price tag shows.
I'd like to find areal basic model. no AS/ power windows and maybe only power steering. Did most include these options? also was any year better than another.
ML
81 and some early 82s had narrower axles and shorter front shocks (these are referred to as narrow-trac or NT axles) so most people prefer the later models for the slightly wider stance.
If you're interested in swapping axles out though, the early ones are fine.
Welcome and good hunting. Post lots of photos when you find yours :D
Hi Michael,
Welcome to the group!
I also belong to a local Southern California Scrambler group. The website is: www.socalscrambers.com
One of the members was selling a Scrambler, I don't remember the details, but if you join the forum, you can check out the "For Sale" area.
BTW, where in So Cal are you located? I'm in Lake Forest.
Paul
Not too far north of you up in Fountain Valley, We are down in LF frequently at the inlaws.
ML
