jsteed
- Tucson
- AZ
Hey everyone, I just had a 81 CJ8 follow me home. At the time, I thought I got a pretty good deal - after closer inspection, I probably paid too much. Its fairly stock, I think the only mod is the weber carb and the 1" body lift. Its got a lot of rust... to the point that the tub may be a goner. I've never had a scrambler before. I was starting in on a 47 CJ2A and it occurred to me there is virtually no practical use for it other than off road, and even that's debatable. So I found this guy, and paid $3900. it was a daily driver. seems to start and run pretty well. leaks oil, probably a rear main. clutch chatters. Engine has no smoke, and seems to generate adequate power (though I have no basis for comparison). does 55-60mph no problem on the flat. Theres some gremlins in the electrical, as I would expect. The harness looks like a wire recycling bin. The rust is all in the tub, maybe a little in the frame. plan on driving it for a summer, then get in on the body work. Theres lots under the hood that I don't understand. much more electrical than I would expect for a carbureted vehicle. and a lot of wires that just seem to go nowhere.
No idea what this is...
So... plan is to just drive it for a while and see what happens. look forward to reading and learning more about theses things.
