New shop ideas
Grey Fox
Bountiful
UT
Within the next year Im building a new shop/garage. Probably 40x50'+. 3 overhead doors. Im looking for good ideas and suggestions on,
Outside design
inside layout
bench and tool organization
lifts
So if your proud of your work digs show us some pictures.
Kim
Check with the County first.
I had a pretty big idea of what I was going to do, but once I went to see about permits I found out that if I exceded 1000 sf I had to do a lot more engineering, and the fact that I had a 1 story house limited my garage to 1.25 times the height of my roof.
I still managed to get a nice 30x32 = 960 sf with a second story storage place. I just had to do a little creative design to get it all in there. But I do have three bay doors and can get my truck and 2 jeeps in there and work on them.
Carl
Whatever you decide install a drain so you can wash inside. I had a neighbor once who had one and I thought it was great. Mine doesn't and I wish it did. Would come in handy when painting also (wet sanding) all that kind of stuff
I have been in contact with the city and they do have size restrictions and will have to conform.
Jason, putting a drain in is a very good idea, never thought of that.
I am working on my new shop right now. It's 30x60, It is for more things than just working on vehicles. I do wood work and metal work in the same place as working on my rides. A major consideration in my constuction was efficeincy. I built mine out of block grouted solid with 2" of insulatlion on the outside finished with stucco, for mass. Lots of windows on the south for solar gain. I am trying to have a work space that has to have as little input for heat and cooling as possible. I also installed 4 14" sun tubes for lite. I am very pleased with the amount of lite they put out. Just my .02$
mine was built from lumber like a house so multiples of 4 make good sense...mine is 32 x 56...other than that ...i like my 12' walls and 10' high doors....go with 2x6 walls and insulate well..my shop stays 57 degrees inside no matter what the temp outside gets..and that is with no heat
There may even be restrictions on putting in a drain. There is a restriction on that here. I still put one in. My builder sealed it over with a thin layer of concrete, then removed it after the occupancy permit was issued.
On an equipment basis... I always wanted to have a stacked washer/dryer in my shop so I could wash the nasty crap separate from other clothes and not in the good washer/dryer.
I would watch Craigslist for a cheap used setup and just keep it in mind when laying out the power/sink plumbing.
garagejournal.com forums, more good info than you can shake a large stick at
I only built a 26 x 30 two story with a full shower/toilet and sink downstairs and a sink upstairs. Insulate well. Install a on demand hot water heater ( Home depot $189) and a drain in the floor. I also have a double insulated air compressor room inside with tank drain line going outside. I mounted a wall switch w/red light on the outside so I don't have to open door to turn off/on and can tell by the red light if I leave it on. Run 220 outlets to each corner and I installed overhead air hose / 110v retractable reels. Shop vac on wall with a 20' hose and plenty of cabinets. Plenty of 110v outlets waist high. Figure out where your main work bench will be and wire tons ouf outlets and an overhead light plug for shop lights.
Did I miss anything?
Oh yea, make sure when you install the ceiling lights that you can see all of them WITH the garage door(s) up! I goofed on that one and need to move my lights back about 3 feet. Thats on the VERY bottom of my todo list.
Hope this helps.
Bill
Ok I've just spent about 2hrs on Garage Journal.com. Thats a great site.
Scott I don't speak spanish but I think its saying "Size matters" ?
Gettin some good stuff here.:cheers:
If you can do it, include a bathroom with sink, shower and toilet. Make sure you have places to plug in high voltage stuff throughout. a soundproof (sound deadening) room big enough for all of your loud equipment to run (airtanks, generator, etc...), wire for sound and internet. Nothing quite like doing research on your project while your sitting next to it. Drain(s), an externally vented flammable storage locker is always a great idea. Make sure that you have an area that you can close off completely for clean work. Nothing like putting that final coat of poly on the wordwork to have dust fall in it, especially if it's metal dust. I've also seen one shop where the guy used an overhead arm (like the type you find in a do it yourself carwash) and instead of a waterhose he had an electrical drop cord and airhose on it. (made it real nice going from one side of a project to the other) Make sure you can vent the heat out in the summer along with heat it in the winter.
Before I got married my dream house was a one room(2 if you count the bathroom), 5 stall garage. One stall with doors on both sides so I could drive a boat trailer straight through and not have to back in. (I also wanted to have a fish cleaning table on the backside and a place to hang deer)
Something else, nice is a kitchenet. a place to plug in a coffee pot, kegerator and heat up bean burrito's at two a.m. without waking the wife. because of course you'll be sleeping on the cot. (sorry thats me)
You can see the start of mine on my website. It is 30"X68'X12" Four 10X10 doors. The house will sit on top. I think I have a photo of my old shop on the Jeep page as well. The new shop will have the same roof design.
Dean
