bigwalton said:Anyone that wants to let someone have a shot at one of these "old" trucks of y'alls, PLEASE post up
....someday....![]()
So let me understand, Dan... that thing has a turbo AND a supercharger???
"F-250 Super Duty 7.3 Turbo Diesel Super Charged"
Wyoming said:Here's mine too bad it only has the little V10...
Geezz...thanks. Mines a 2005 6.0.jeeplady1965 said:...the 6.0's that have been coming into our shop, stay for months...one problem after another. So if you have a 6.0, stay on top of your maintenance.
John N said:I have an on-going issues with the dealer on mine. When you throttle it with more than light pressure, it makes a popping sound, both acceleration and deceleration. This is with only 13K miles on a 2005, started about 2k ago. The dealer says it's "air box turbulance" and nothing to do. Crossbones had the same thing; it went away when he had them replace the EGR valve. I'm about to go after them again on this, I loose power when it happens too.
I don't know what turbo bark is, so I can't say. It's pretty loud, scared my wife when she first heard it. The truck is totally stock.ilovetrains said:When you say popping sound, do you mean like a turbo bark?
John N said:I don't know what turbo bark is, so I can't say. It's pretty loud, scared my wife when she first heard it. The truck is totally stock.
It usually seems to happen between 15 and 20 PSI of boost, beyond that...I just can't say what it is.ilovetrains said:Turbo bark is what happens when the turbo boost exceeds the air the engine can use. This usually caused by the turbo spooling up and the driver suddenly retarding the throttle. The air in the intake then runs backward for a split second as it has to escape somewhere, and back through the turbo is the easy path.
The sound is usually loud as the air hits the turbine blades and may even stop the tubo for a split second. This can cause damage to the bearings in the turbo assembly, as well as the vanes of turbine. When turbo's seperate they can cause a great deal of damage. On a V8 the turbo is often placed high, consequently when it shells it hits things like the fuel rail. On a straight 6 the turbo is often low and if it shells most of the energy goes into the block.
If you are developing a good amount of boost and then pulling out of the throttle too quickly, you will bark the turbo.
John - did you add an aftermarket boost gauge or is that standard (or optional) equipment on your truck?John N said:It usually seems to happen between 15 and 20 PSI of boost, beyond that...I just can't say what it is.
Oh, it definitely does it when I get off of the throttle during hard accelleration. That's how it started first, then during accelleration, then under lighter throttle too.ilovetrains said:I hate to tell you to try it to see if that is the same sound. My guess is that is what you a hearing.
John N said:Oh, it definitely does it when I get off of the throttle during hard accelleration. That's how it started first, then during accelleration, then under lighter throttle too.
