Not very happy with Tom Woods driveshaft
ilovetrains
slightly backward
Lee's Summit
MO
I hate it when people get on a forum and start rambling about how crappy some product they bought is. But this is pretty much driven me to cussin' this morning.
I put a Tom Woods CV shaft on my TJ a little over a year ago. This was part of an Advance Adapters SYE kit. I was pretty pleased with it at first, however after a few thousand miles I re-geared. After the re-gear I noticed a slight vibe coming from the shaft that intensified with speed. We had the shaft balanced, and it was over an ounce out of balance. On a shaft that short, that is pretty ridiculous. But no worries, it worked, and I have put a good 25K miles on it.
After a run about a month ago I heard somewarbling from it and the vibes were back and strong. I looked at it and saw a grease pattern accross the bottom of the tub. I put the grease gun on the u-joint zerks and found they had no pressure, the grease simply poured out the rubber cap end. Oh no.
I pulled it down thinking it was awful quick for u-joints to go bad. The CV staightened out when I got it down and I tried to flex it out. Would barely move at all, much less flex full width of the two u-joints. You got to be kidding me.
Not wanting to tackle this I took it to Spicer place (Inland truck Parts) this morning. They guy laughed, do you want a new one, would be cheaper than trying to rebuild that piece of crap. The ball and pin are shot. He laughed harder when he saw all the weight to balance it.
So now I am not very happy iwth Tom Woods.
Yea these internet/offroad famed driveshaft shops sell you nothing better than you could buy for less at any local driveshaft shop. They have effective advertising though.
A total rebuild on a CV shaft with spicer parts and balancing should run you $150 from a good shop. I would think that with lots of trail riding and sharp angles, 25K miles on a shaft would be pretty good. A standard u-joint is designed for 100K miles average life at a 2 degree operating angle. Service life decreases exponentially with increased angle and increase torque.
I don't think Tom Woods shaft is any better than a reputable shop would make. They are using the same parts after all. However, they do have a little better knowledge of the 4wd market where stubby shafts or longer travel splines are required.
I have personal experience with Tom Wods Drive shafts, if you call them and tell them what your problem is they will take care of you, sure you might have to mail off your part but they should fix it.
To Woods has a really good rep, I'd be surprised if they let this slide...:)
EXACTLY the reason I use a shop like Woods. Every local driveline shop I have tried to use did not understand what and how we use our rigs. They acted like typical parts store kids, i.e. whats the make/model/accessories??:rolleyes:
I have been running TW shafts for the past 4 years and have had no problems. Like said above, give them a call and see if they can help you out.
I spoke with Tom Woods, kind of surprised he answered the phone. Anyway, it had a 6 month warranty, and I am out of warranty. He said if I send it back he will look at it and perform all repairs as fairly as possible, calling with an estimate before he began the work, but he anticpated it might be due to excessive lift or maintenance issues.
I did not tell him how much lift I had or how many miles it had on it.
Why didn't you tell him about the lift? if they had know all the variables when you began you probabaly would have gotten the right drive line to begin with. If you told him about the lift he might be able to fix what you send back to him, like build it to suit your vehicles needs (additional slip in the slip shaft, etc..).
I have tow beat up CV (double Cardan) joints and both of them have burnt up centering pins, they are greasable but I didn't know where to put the grease until 2 nights ago :p since I don't drive the vehicle on pavement for more than 2 miles or so, AND there are many other noises/vibrations I don't really notice a little driveline vibe.
I always perform maintenance on my rig after or before a trip to the trails, especially if I've been driving through water. It sounds to me like you might have been negligent in your maintenance, if you had greaed the pin, your vibs would not have appeared.
Hopefully TW will hook you up on the rebuild.
I have to be honest, i wasn't really happy with my last encounter with Tom Woods driveshafts either. I had them make me a front and rear shaft. They both were great and I love them. Then I had sent them both back to be lengthened. The whole lengthening on both shafts was $60 total. They worked fine after that. I recently bought my scrambler and did SOA on it. I reused the driveshafts on the scrambler and had to send the front back in to be re-lengthened. They charged me $60 for just one shaft. When I told them thats what I paid for 2 lengthened shafts last time, the salesguy just laughed and said I was mistaken.
I like their shafts, just not to happy on the inconsistency of their pricing.
I think you missed my point. This was a custom order driveshaft for the lift I have on my Jeep. It was actually part of a package put togther by RE, Advance and Tom Woods. It featured there high angle u-joints (an upgrade over their regular shaft). I know where the grease zerks are, and had been greasing it regularly.
Tom responded before I could explain that the failure was due to too much lift and/or imporper maintenance without even questioning what lift I had or what maintenance I do. If the shaft was not built for the lift, then how is that my fault? I ordered with exact specs on lift and length. If it was maintenance, then yeah - it is my fault. However, shouldn't you ask the question before telling someone that?
You had been greasing it (all of it) regularly in that 25k miles, right? ...Using a pin adapter on your gun to grease the ball/pin that toasted? As Mark said, lots of folks don't know how many places there are to grease a CV
As has been said, I bet they do right by you if you send it in...
oops, started this reply before you posted... ultimately there's only a couple of things that can go wrong with a dshaft and if you made it 25k miles, it's not going to be a material defect, lift or maintenance is all that's left, so naturally that's what they'll mention...
When I got it I ran up to O'Reilly to ask what the heck that was as my regular grease gun would not get it. They gladly sold me an attachment for it.
Guys i'm not going to get into "who is at fault here".......there are way to many varibles....such as was this strictly a DD or has the rig seen mud which will wear one out very quickly and can reduce the u-joint life by 3/4's, was one of the balance weights ripped off on a rock,were the u-joints ruinning in the proper phase,how often was it greased?....I do mine at every oil change on my DD truck (3000 miles).what type of grease was used,regular grease or high speed grease........etc. I have run Tom's shafts for years and have never had a problem or failure yet from one of his shafts and a few of you have seen me drive.......I ran a rear CV in mine before the rebuild and never had a problem even with 39" tires but one thing i did find with mine was i had to remove the transfercase side of the driveshaft to get it greased properly which meant forcing grease through it to flush it,not stoping when you just see it peeking out.........took a little time but i did it after every hard ride if i had been in any mud or water.....if it was just rocks then i would do it about every 3rd run,the secert of keeping u-joints alive is grease,grease,grease and then more grease..........then making sure everything is tight at the yokes. As far as the cost, the price of steel has went up a ton in the last couple of years what i use to pay a dollar a foot for is now 5 dollors a foot at my brother-in-laws cost, the tube i used to build my axles was $20 a foot at my brother-in-laws cost,$24 a foot resale, a year ago it's now somewhere around $40 a foot (at cost) at todays prices. I just ordered my new rear shaft from Tom and will order my front from him also when i'm ready for it........Tom's always been fair to me and has given me great customer service.:D
Bottom line
If you wheel--stuff is going to go south. No matter what product it is.
Kinda like when I blew an OX joint and a chromo inner shaft--going staright up a small boulder--BOOM!!!! Who's fault? Its "wheelin" fault. I guess thats why some of us have spent over 10k in just axles under our rigs....
crash said:
Bottom line
And they Always go boom when least expected and usally take out something even more expensive,right mopedal-lol :D
You knows it brotha JC ;)
I wished I could get 25k out of mine! Last weekend I got my front dshaft. It's only 3 rides old....We're talking about a special made $400 shaft! (Local shop by the way) We were out, having a great time, going over this pebble, then that pebble, up the water falls and so on and so on. When all of the sudden my front tire slid off this pointed pebble right on the dshaft. Didn't realize it at first so naturally I MoPedal'ed it trying to get off the rock, sparks going everywhere! Poor thang looked like a chewed up boomerang! When we got it off the rock it straightened up pretty good, well maybe kinda good! I'm sure if I hadn't put so much money in it, it probably wouldn't straighten up at all.lol It actually lasted the rest of the day!
Moral of this story is if you play you pay! That includes going down the road with it all jacked up! It's just gonna happen.
I've allways built and balanced my own, and haven't broken one yet. My old rear shaft was 2" sch80 pipe for the tube. Didn't have to worry about dropping the jeep on it. My front shafts had allways been 1 1/4" sch40 and did get bent over time, untill one day about a year ago I stripped the splines, blew 2 axle shafts, a u-joint, and a hub in a front wheel burnout on the street. Didn't find the stripped splines untill the next wheeling trip so I found a welding shop with some square tubing to make a temporary shaft, and still haven't replaced it. The thing shakes at 10 mph and makes lots of noise, but has been working. I'd occasionally blow out 1310 u-joints and once ruint the rear d60 yoke, after that the needle bearings in the joints would last about 1/2 mile.
Tom Woods drive shafts
I have always had really good experence with tom woods drive shafts. I also carry a grease gun on the jeep. My grandfather has a Grease gun on the tractors and the other grandfather had one on every piece of mining equipment when we were mining coal. I was taught to hit the fittings frequentlly. I usually hit every fiotting before I drive home during air up. Saves lots of U joints and bearings.
I used to buy from Six States while Tom was there. I also used Tom's pieces for every project that I've created... until he got so busy that he let Troy run his shop. My experience with Troy was that he slapped stuff together and sent it out the door. He knows better, he just didn't care if it came back. I'd investigate if he still works there. If Tom sees it, it does not fly. Unfortunately, Tom is hard to contact these days.
