OT: air compressor wiring help
Truck
Manassas
Va
Okay, I picked up this compressor the other day. It is an older Keystone compressor. I can't seem to find any information on this compressor anywhere. It seems solid, pump seems to be compressing when I turn the wheel. Here is where I need help. motor says it can be wired 230 or 115. I'm not sure how it is wired now. I want to wire for 220. So here are some pix to show. If any one can help explain what I need to do that would be great.
Compressor and pump
Motor ID plate and wiring on the other side...only black and white come out of cable to connect...the yellow, blue, red and gray all go into the motor
This is the shutoff switch box and how it is wired
Finally, this is the current plug on it.
Truck
Thought I'd post a few other pix
Motor..can't see it very well but the ground wire for the 12-2 going into the pressure switch box is not hooked to anything. No ground wire coming out the other side and into the motor
These were in the box on top of the motor. Capacitors? I figure I ought to clean up the corroded connections right?
Truck
I replaced a couple of the pictures in first post with better ones
This lub instruction plate was on the motor...where do I put the grease?
Truck
I know enough to be dangerous.....
Truck, with the plug on the end of your cord, I think your already wired for the higher voltage, 220/230. That looks like the old A/C type plug on big window units.
That is a 220v plug. For the grease look on the end of the motor for 1/8 " pipe plugs top and bottom take both out put a zerk fitting in the top and grease untill new grease comes out the bottom run it for a while untill no more grease comes out and reinstall plugs Then you are done.
be very careful with theose capacitors! as you probably know, they store energy, you don't want to be their discharge path! I think the previous posts are correct, looks like single phase 220v to me. Lube as suggested, the plugs may be a phillips looking cross though instead of a traditional square head plug, MAY be
