i used a second factory bar, lopped off the kickers, reversed the bar and used he kickers as spreaders. Nice solid family cage. Using the scrambler bar keeps all the tube the same size and looks cleaner than different size tube. here are a few pix. also used smaller tube to make a swing out utility carrier that swings out either left or right. holds tire, gas can, power tank and pressurized water can. The CB and ham antennas are inside the rack, but mounted to the cage side, not on the swing-out. Added some mounting tabs to top of bar to add a light weight roof rack.
Where did you get the 8 lug trailer hubs from?
