crash
Mad Scientist
- Gold BAr
- WA
One isse that we had found with hydro, the power steering pump reserviour isn't large enough for when the ram contracts, causing fluid loss, and even worse on sidehills with the driver side on the downhill side. There are a few options. One I actually stubled across when I did mine. When I did mine, I just used the stock saginaw pump, and was runing into the fluid issue. It just so happened that I gutted an astro can for a buddy, and saved the pump from it(this was actually a year before) and was going thru my stock pile when I found the pump. They used a sealed tank with a remote reservior, perfect. They used this setup on the astro's from 87 and up and on the G-van (gm full size van) from 88 and on up. Unfortuanately, I was not able to locate these items easily on jeffs, so I opted for the other method.
First, I removed the pump, cut about 1/2" off the top where the twist in cap sat and capped the hole and drilled and tapped it.
Now that this was done, It was time to figure out what to do for a reservior tank. I took a peice of pipe, capped the bottem end, tapped it, and took the part I cut off the power steering pump and welded it to the top of the pipe and made mounts.
One thing you have to make sure, the res tank is higher than the pump so you don't trap air in the system..
