Project Zebra!!!!!!
Osprey
The Duckbum
Cambridge
MD
In my best mad scientist laugh - - Buuwaaaahaaaahaaaahaaaaa, It's BEGUN! From the very beginning of wanting a Scrambler over 20 years ago I always wanted a zebra stripe one, so here I go!
I read the cheap paint job thread on using rollers and implement paint, planned on going that route but wanted to try a piece with rattle cans first. Had a set of half doors I'd gotten that needed to be painted (and remove those stooopid purple stripes that came stock on them!!!) so I started one of those with the spray cans. Prepped it, did the black base coats, sanding between coats, taped it, did the white top coats, final wet sanded with 1000 grit, buffed it for 15-20 minutes with polishing compound and a power buffer, then waxed it. Turned out pretty good, sort of a satin finish when you look straight on, but glossier from an angle. Very crisp and clean though, and looks good on the Jeep. I may not even try the rollers, I like it that much with the stripes. And I'm using Tractor Supply gloss white and gloss black farm implement paint!!!
Now on to the next piece of Jeep to prep and paint. I feel like a parody of the old Johnny Cash song - "I Painted it One Piece at a Time..."
Bwana Osprey
Ted Nugent would be proud...
I can't wait to see the rest! Looks cool!
I had some pics of a Scrambler painted Kawasaki green with metallic blue tiger stripes. Looked awesome...I'm just not brave enough to do that to mine.
I think it turned out good. After sanding, is it pretty smooth between paint colors?
Truck
Yea he would. Years ago I remember Ted Nugent's Bronco showing up in the latest 4X4 rag. Man that thing was cool.....
Truck
You can feel a bit of an edge if you run your fingers across it, but not bad. The last sanding and buffing took off the worst of it. A buddy that owns a body shop is going to get me some different compounds and pads to see if the gloss will come out better, so I'm anxious to try that after I do a few more parts. The other door and tailgate are off, going to start sanding and prepping them today. This was my first ever attempt at body and paint stuff, so I've got lots to learn. But I'm quite happy with things so far.
I've seen Nugents bronco on several of his TV shows, it's pretty cool but not my inspiration. Anybody remember the old Southern Sportsman outdoors TV show with Frank White? He had the coolest zebra striped airplane he flew around in to go hunting and fishing!!
That's what color my son wanted to paint our red one....
Your's looks great!
A guy here has an old Dodge cummins in Zebra, he started white and projected a transpancy of an actual zebra onto the truck and used that to guide the masking, then shot black. Looks good and definitely suits the truck, and him
sluggo8 said:
is that a white door with black stripes, or a black door with white stripes???
Black with white stripes, it's the lesser Kalahari subspecies. :)
