Rear Frame Rust & Repair
Grey Fox
Bountiful
UT
I thought I had an OK frame until I had to drop the gas tank. Was I ever disappointed to find this. The longer I've owned this Jeep the more I'm convinced its lived a hard life. The body mounts have somehow been pulled or rusted out and relocated. The frame rails were full of rust and dirt. Etc, Etc. But its my child now and ya just don't bail on your own child just because it has B.O.
Ouch... that's unfortunate.
Funny way to put it, but you're right of course :thumbsup:
I knew I had rust and dirt inside the rails so that had to go first. The back bumper was welded on so it had to be torched off. Like I said I knew I had rust and dirt in there but this really surprised me. 20 lbs!
Next I cleaned up the rusted areas and cut out the center cross member.
I bought 2 pieces of steel
3/16" plate X 8" X 60"L With a 2 3/4" bend
3/16" plate X 6" X 10ft L
At this point I took rough measurements and make some cuts so I could get the steel clamped to the frame. Once clamped in place I could refine the fit. You'll notice the body mount was only cut on the sides leaving the top still in tact. I saw this on Chiefwaho's frame repair site, other wise I probably would have cut the whole thing off. Thank you CW.
I liked the idea of using a bent piece here to rap the bottom. As you could see the frame was so deteriorated that I wanted to add vertical strength as well as lateral. Bent steel would give both. The underside radius was a little tricky as it turns up then back the other way, thus the notches for the second bend.
Getting the second radius required clamping heating and tightening. Once formed, tacked it in place to move to the work bench for the finish. Welded up the back and front of the bends then hand grinding put on the finishing look. Welding with the body on made it difficult in some area's however it was do able. For you Scrambler purists you may have caught that the body mount was not in its original spot. I refer back to my original post " This Jeep has lived a hard life". The last picture is what happens after a long day.
I hope you guys aren't gettin bored with this.
I bought new shackle mounts and made a new captive nut plate since the original nuts in the frame were toast. This was made from 2 square washers and unistrut nuts, nice and heavy, easy to weld on. This just laid inside the frame over the shackle mounting holes.
The inside plate was easy to cut and fit.
Not sure I needed to do this last step but I wasn't sure how strong the frame was at the point where the re-enforcement ended. Didn't want it to break off there after all this work. So I extended the plating forward just on the outside. Again much of the design and inspiration came from reading and studying Cheifwaho's work. This forum is a fantastic place to get ideas and information. Lots of smart guys out there. I've got a couple of things to still do to rap this up,
1. Weld the gas tank cross member back in.
2. I think I'm going to coat the frame with POR 15, as the previous owner had done that.
3. I just realized I don't have a picture of the finished job. Maybe tomorrow.
Great job! I love the documentation, that will be a big help to others.
Yep, this is awesome/perfect. I'm just about to start correcting a very similar "fix" the PO did to mine. They must have been drunk or doing the work on uneven surface.. Anyway, great stuff, will come in handy.
Where is this Chief Waho's site/stuff so that I might also read up?
Great write up! Keep up the good work! :cheers:
I'm usually not squeamish, but those frame gunk photos almost made me hurl.
Wrench party!!!! :D
That is EXACTLY what is needed for mine, only on the other side. WOW I love all the pictures. Thanks for posting this. :thumbsup:
Still haven't figured out who I'm going to get to do this as everyone wants to simply put in a whole rear end section of the frame.
Got a guess of how many hours of labor it took to do this?
Great work.
I hear ya,
It was good to get it out. It was caked in there so bad I stuck a 10ft section of a spring steel fish tape leader in, clamped my cordless drill to the other end and beat holy $#!* out of it. Then got the shop vac hose in to suck it out. I now know why they put those little holes in the frame. Its to feel the level of your gunk.
Scramblin Jim, Hours is a tough question, I've been working on it for 2 weeks mostly at night after work and one full Sat & Sun. I did a couple things you probably wouldn't do like the rust and dirt inside the frame and I was messing with the leaf springs trying to correct a leaning issue. My pictures only show the passenger side however I did the re-enforcement on both side's. Regardless of those extra things it still took some time. With all my head scratchin and over thinking I'm sure I had 30+ hours. Show some of these pictures to a professional shop and I'm sure they could do one side in less than a day. Good Luck
