Rewind
congrats man......looks like its really starting to come together! When do you hope to have the jeep done by?
-WIll
I've given up on putting done dates on it at this point...seems like there's always something lurking in the shadows to foil my plans. Right now we're shooting for being done with the major fab work either the weekend after Thanksgiving or the first weekend in December, at which point I'll trailer it back home and tuck it back in the garage. The mission right now is to get my garage back in order and finish up a couple of things on my CJ-7 before then. From there, it's get as much done as I possibly can during the Winter...once Spring hits I have to finish getting the house in sale-able condition and start looking for a new place with more land and hopefully an existing pole barn or extra garage so I don't have to build one. I want to at least have it together enough to drive it on & off the trailer when we move.
-Rodney
Not a very photogenic weekend, so I left the camera in the truck. Anders finished up the C-pillar frame tie-ins (he also plated the rest of the rear of the frame rails and bent the ends of the plates and ran them behind the rear crossmember to funtion as tie-ins for the rear bumper as well instead of using the separate bolt-in reinforcements) and we sorted out the A pillar tie-ins. The trailer-fender wheelhouses are welded in, just have to make the filler panels for them and weld those in. We worked on the mounts for the eyebolts for the rear snap-in harnesses, just need the nuts for those and they're done, and we tested the removable rear section of the cage (it shifted a little when we unbolted it, so we persuaded it back into shape with a bottle jack). After growing weary of waiting for a certain vendor to release a version of their t-case output mount to work with the JB rear output housing, Anders chucked a piece of 1/2" steel in the mill at his father's machine shop and fabbed one up, which I test-fit and positioned on the new crossmember...just has to cut a slit in it and finish machining it for the clamping hardware. He should be picking up the tubing today for the tube flares, so we'll figure out the bends for those next weekend.
Didn't bring the camera with me this time & wish I had. Anders finished up the t-case mounting bracket and it's installed along with the rear tube of the crossmember. We're about 2/3's of the way done with the front tube of the crossmember...working around the front driveshaft with the doubler setup is proving to be a bit of a challenge, but I think we've just about got it licked...one of those 'in the zone' things where stuff just starts clicking and falling into place. Basically we took the original tube crossmember that we'd made, re-bent it to match the new rear tube and cut one end off and welded on a plate that the factory auto trans mounting bracketry bolts to. Then took a final measurement for the cut end and sliced it right next to the plate at a 45 degree angle and sliced a short piece of leftover tube at 45 to mate to it to begin the upward climb up & over the front shaft...it'll make more sense when you see the pics ;) If he can get a hand or two during the week to lift it out, the cage will be finish welded this week and I'll be bringing it home to prep & paint. Heading up on Saturday again and I'll bring the camera this time.
If there are no issues/surprises, it looks like I'll probably be bringing the Scrambler home New Year's weekend. We finished up the cage (handles & gussets) today and I brought it home...I'll take pics of it tomorrow. Anders finished tacking in the trans mount crossmember bar last week, so we'll probably finish that when I go up on Friday (have the day off, rest of the family doesn't, so I won't be missed), and he started on the rear truss and just about finished the gas tank relocation. Here's a few underbelly pics:
Tube flare pics
Here's the tube flare pics (fiddling with the camera settings, so they're a bit over-exposed) from Friday's session. Drive front just needs to be tweaked a bit, then the fronts can be finish welded (rears are done)...I'll skin them later, though I do kinda like the 'skinless' look so they may stay that way.
Rodney...i love how your design on the mounts etc...you are a man of my own heart...everyone always questions why i do things how i do them..and i like to be a bit different...i got some ideas from those pic...i hate the guys ...not really.. but ...the guys from pirate that get an idea and just suddenly everyone does the same thing..i love the new ideas...anyway...i would love to spend a few hours bouncing ideas off each other ...i really like how u think
Looking good,............must feel good to be making progress. When do you hope to have it done by.
-Will
Definitely feels ggod to be making steady progress. Not moving along as quickly as I would have liked, but that's life...better to take a little longer than to do something I don't really want/like just to get it done.
Scott, I honestly can't take a ton of credit for the design work. It's a mix of my ideas (overall cage design w/the removable section), unique/interesting things I've seen on other rigs (the center U's and the pass-thru on the cage, M-Cor's engine cradles, Roark Fab's t-case mount, PSC's trail flares), Anders' ideas/structural adjustments (it was his idea to turn the A & C pillar legs inward), and a bit of the two of us just thinking on our feet as things came together and we ran into obstacles. I think you'll like how the rest of the belly crossmember comes together and the rear truss/traction bar setup (some of the pieces are done for that, I just didn't take pics of them yet since we haven't fully fleshed it out). Finally stopped raining today, so I'll put the finished cage pics up soon...it's sitting under a tarp in front of the garage right now.
Moving right along...Anders finished up the front tube flares last week and started on the rear truss and did the finish welding on the engine cradle, gas tank relocation brackets, and front cage tie-ins. I went up Saturday and we finished the crossmember (had to relocate the t-case support bracket higher up as well), worked out the trans/oil pan skid, and made some more headway on the rear truss. He expects to be done by Wednesday, so I'll run up with the trailer on Thursday or Friday to bring it home.
Well, it's *almost* home. Since I'm working third shift right now (I'm at work as I type this), I went to sleep when I got home Friday morning, got up around 3, did the 3 S's, hitched up the trailer and hit the road a little after 4 PM. Was loaded up and back on the road around 7:45, grabbed some dinner, and went to work, so it's sitting outside hogging up about 5-6 parking spaces :D There's still a little work for Anders to come down and finish up (he needed the shop clear for another job on Saturday plus some of my other parts need to be in place): weld-on flanges for the engine crossbrace so that the oil pan/trans pan skid is removable (plus I can change the oil pan gasket without removing the engine cradle...I accidently ordered flanges for 1 1/4" tube instead of 1 1/2"), correct 2 body mount brackets on each side, finish weld the top sides of a few of the brackets, finish the bam bar. I'll probably post pics tomorrow.
Cool, I can't wait to read that you've driven it :cool: after all this work!
Of course I won't mind seeing more pics either :D
Congrats on almost getting it home.
Getting ready to unload:
Rear truss/bam bar mount (the all thread is just for mock up...I have to have a u-bolt made to replace it):
Nearly completed crossmember/skid:
Overdue pics of the finished cage:
That cage is almost a buggy frame in itself, mount drive train and axles under it and you are good to go.
Whole thing looks great.
Truck
Wow thats a lot of tubing. I bet that is monster heavy. You could drop of Black Bear or Blanca and stay alive in that. Do you have more money in tube than in the Jeep itself? Cool, very cool.
Truck
Pretty darn close to it. That's actually one of two other Scrambler build ideas I have in my head. If I don't get to do another one, this one may evolve (devolve?) into something more buggy-like. The other one is a daily driver with the AWD drivetrain out of my ZJ Limited.
