But if the ballast is on the ignition coil as shown, shouldn't the starter still turn over.
Sounds like you have a short in the battery or possibly alternator that ran both batteries down. Do you have a volt meeter to check battery voltage?
As mentioned above, The failed ballest resistor would prevent engine from running but has nothing to do with cranking of the engine or engaging the starter.
I always had a spare resistor mounted directly below original so "when" it failed all I had to do was switch wires to backup, then install new one next opportunity .![]()
Well I am ashamed to say that I have given up. I have realized that I don't have the time or mechanical expertise to get the 8 running correctly. Luckily I have a buddy that owns a shop about a mile from my house that is going to tow it there and button everything up for me. I'm just ready to drive it again and move on to other projects I want to get done before we start the addition on our house. That is the good news on the Scrambler. The bad news on the 7 is that I'm not getting power to anything from the battery apparently. The headlights don't even work. The voltage on the battery was like 12.8 last night when I put the meter on it. I'm going to start at the post on the battery with reading voltage and work my way out until I find what's going on.![]()
